Should I Trade My Hallman For....
My friend said he would give me his greddy profec boost controller with all hardware and user manual for my hallman with cockpit controller. I looked at the prices greddy profec runs around 400$ and the hallman runs around 160. What should I do... I want the electronic cause ima go alky kit soon and i dont wanna run 30 psi all the time. The greddy gots a Hi/Lo setting wich would be ideal for my setup.
unless your friend is being nice to you or he try to rip you off with a broken profec b ... I say this deal is too good to be true.
I'll trade it if everything works, complete and legit.
i'd trade him, but if your going alky your gonna need 2 diff maps if you want to run hi and lo settings, cause if your tuned on 30psi and you lower it to like 20 psi your still going to be running the 30psi map and that wont be good
right now i run 29psi on meth and with it of i run 11psi the wastegate spring
I have GReddy profec B Spec II bc, and it usually go for $299.... $400 is the retail.
I liked it very much, it's the best bang for the $ EBC. comes with feature such as switching between PSI, bar mode. records peak boost, warning feature, digital display, start boost setting, gain, and desired boost setting. It's very easy to use unlike my buddy's blitz i color which is very difficult to set and cost a lot.
If you are gonna be running 2 different boost setting, trade it with him.
Ya ill have 2 seperet tunes 1 for low and 1 for high boost. Just ride with my laptop and flash the ecu as needed. Ill talk to him 2marrow im sure he will let me install it to see if its runnin right. (should I still do it if the unit is all scrathed up?)
