Puzzling Issue for the Experts
Old Jul 8, 2008 | 08:24 AM
diablo29d's Avatar
I had something similar happen last year, I had someone put a new BOV on the car and it wasn't installed correctly. Essentially, I had a leak in the intake system somewhere. Not sure if this will help you out, but it may be worth taking a look.
Old Jul 8, 2008 | 08:26 AM
CO_VR4's Avatar
Originally Posted by JKD
Thanks for the advice CO_VR4. I'll check these just to be sure. Everything runs so perfect though. The car runs really strong and does well with everything other than the A/C. I doubt this would be relevant, but I'll look into it anyways.
Once again, thanks for the advice!
You're welcome. Another possibility is that your A/C compressor is going out, and is harder to turn... That would be a better outcome, to be sure
Old Jul 8, 2008 | 08:30 AM
Silver05Bullet's Avatar
possibly the tune possibly the ac going out
Old Jul 8, 2008 | 08:36 AM
rcheung's Avatar
I had the exact same issue which I posted about a few days ago but its hard to search since AC is less than three letters. I removed my ecu fuse and replugged it and thats when it started. It would do the same thing if you were to unplug and replug the battery terminals. I would have to shift very fast or my RPMs would go to zero and idle would be very rough and want to stall. It took 3-4 days for the ECU to learn again and now the idle is rock solid and have no issues when I shift gears.
Old Jul 8, 2008 | 08:41 AM
JKD's Avatar
JKD
Mirror image of my issue. I'm going to try it. It couldn't hurt anything.
Thanks bud.
Thanks to everyone who is trying to help me - means alot. The BOV is stock and hasn't been touched, the tune is wonderful imo, and the A/C works perfect. Guess I've got some digging around to do.
Thanks guys!
Old Jul 8, 2008 | 09:19 AM
rcheung's Avatar
Thanks bud.
Thanks guys!
If its like my issue it will fix itself after a few days. Did you recently reset the battery by the way?
Old Jul 8, 2008 | 09:39 AM
JKD's Avatar
JKD
Yes I did. Unfortunately, it didn't help anything.
Old Jul 8, 2008 | 09:47 AM
rcheung's Avatar
That only starts the process. Wait a few days and see if it fixes itself. Let us know too.
Old Jul 8, 2008 | 09:52 AM
92gsxbaltimore's Avatar
I'm thinking your A/C compressor is binding up. Have you noticed a decrease in mpg with the A/C on? I'm thinking the bearings on the compressor are going up and causing too much load for your engine to sustain while just idleing.
Old Jul 8, 2008 | 11:45 AM
JKD's Avatar
JKD
Thanks again for the advice dude, I'll definately keep ya'll posted with the outcome
Old Jul 8, 2008 | 11:48 AM
JKD's Avatar
JKD
This is exactly what I'm thinking also.
The decrease in MPG on the highway isnt drastic. With 5-10 WOT pulls, 80mph speeds, and A/C on I still manage to get 24mpg on the highway. So no, I don't think my mpg are affected. However, it just seems that its loading the engine hardcore. Definately with the A/C on (BADLY) and even with it off it seems a bit loaded down.
Hmmm
Thanks for your input
Old Jul 8, 2008 | 11:49 AM
Mellon Racing's Avatar
pm sent
Old Jul 8, 2008 | 01:06 PM
I cant remember, but isnt there a A/C idle step setting in ECU flash. I'm starting to think it isnt the compressor itself based on the fact that your mpg isnt affected.
Old Jul 8, 2008 | 01:20 PM
gsrboi80's Avatar
100% correct happens everytime the battery is disconected these cars really need to relearn idle. Both with the AC on and the AC off 3-4 days and it'll likely correct itself
Old Jul 16, 2008 | 01:20 AM
macevo8's Avatar
bringing this back from the dead but I wanted anyone who is interested in- or is currently having- this problem to know that I followed the advice of rcheung and I am happy to say that for the first time in 2 years i drove around the city, stopped at stop signs and red lights with the a/c on and had zero issues with stalling. Its incredible. I was so used to turning off the a/c everytime I exited the freeway that its hard to not reach for it everytime I hit the off ramp. I left my house one morning and turned the a/c on immediately, I did stall on a few stops at the beginning but it eventually stopped happening. Thank you rcheung for your valuable advice, my 110* plus days are no longer unbearable
