samco inlet hose question
Old Jul 10, 2008 | 07:00 AM
zeus1's Avatar
i just got one of these and about to install it. i believe the the smaller nipple is supposed to be capped or something because i dont have an line to connect to it? if so what do you guys use to cap this?
Old Jul 10, 2008 | 08:27 AM
urslo4n8's Avatar
Why not just use a small vacuum cap?
Old Jul 10, 2008 | 09:24 AM
Jeff_Jeske's Avatar
Nothing needs to be capped unless you are running a MBC. If you are using the stock bcs or GM3 port there should be a line going to it.
If using a MBC you should switch to the GM 3 port and pick up a ton of top end!
Old Jul 10, 2008 | 10:08 AM
zeus1's Avatar
yeah i figured it out and put on a vacuum cap..i didnt know they even existed..duh
Old Jul 10, 2008 | 10:21 AM
mini_evo's Avatar
For us not so smart people out here... what is a GM 3 port?!?!?!
Old Jul 10, 2008 | 10:39 AM
wingless's Avatar
Tuning forums>ECU flash>ECU controlled boost>GM 3port BS
