Update on my boost problem
Old Aug 2, 2008 | 09:13 AM
def1's Avatar
A while back i posted about how i was only boosting 12 psi on the autometer gauge. I installed a hallman pro bc and it fixed the problem. Im running 18 psi until i get tuned and the boost really holds well no taper at all. The car is running way faster than it ever did. Im really happy with the outcome.
One thing tho is I dont peak beast til about 3.5k to 4k is that normal? Is there any way for faster spool. I got my intake and exhaust installed. I still need to get tuned tho.
Other than that tho the car runs great
Old Aug 2, 2008 | 09:17 AM
JakeTheVIII's Avatar
Good to hear you figured it out. As for the spool, you shouldn't really have anything to complain about on the stock turbo, make sure you are in a lower gear to spool up quicker, it should spool right up immediately.
Old Aug 2, 2008 | 09:27 AM
def1's Avatar
yea your right i was doing pulls in th 3rd and 4th gear. ill go ahead and do some runs in 1st and second and see the spool there.
Old Aug 2, 2008 | 09:45 AM
alloutDSM's Avatar
once you get it tuned on some more boost you will def feel the difference!! glad to hear you ride is coming out good!
Old Aug 2, 2008 | 11:01 AM
Duh Panda's Avatar
tune does make a big difference
Old Aug 2, 2008 | 11:54 AM
def1's Avatar
i think i found the problem. my stock vac line broke off. i know its not being used anymore but i was told it still needs to be there. Here is a picture of what i am talking about.
also i dont know if i was supposed to cap off the other thing
