Launch Control problem
Old Sep 13, 2008 | 08:40 AM
brandEvO's Avatar
I've searched a lot of threads and I know the subject has been gone over 1000 times, but I have a little bit of a unique problem I think.
I've read my Rom and my stationary rev limit is at 5500 rpms, but when I put the clutch and the gas down in 1st gear at a stop, it just goes all the way to redline. I may be doing it wrong, because I haven't had my car long. Its an '06 Evo IX RS. Just wondering some problems that might cause this if I am indeed doing it correctly.
Old Sep 13, 2008 | 09:42 AM
redboosted05's Avatar
Mine does not 2 step either. Mellon flash 2 step doesn't work....went on the dyno with Dynoflash 2 step doesn't work either. So after testing the wheel speed sensors they checked out and the clutch switch is working as well it has to be something with the computer itself. I will investigate that if it does not work once I get an AEM installed.-JOEYD
Old Sep 13, 2008 | 08:07 PM
EvolNinja's Avatar
It should work. I'm sure your car is in a flat road when doing this right? Anyways, put the car in 1st gear with clutch in, rev to about 5500 rpm and you should hear a pop pop sound. You don't need to go past that. If you do, you're doing it wrong and just reving to high.
Old Sep 13, 2008 | 08:51 PM
joyce1bro's Avatar
mine also doesnt work and its also set at 5500. tried it heaps of times... stopped clutch in and in first gear nothing, straight to redline.... clutch out in neutral and nothing... redline!!!
not sure how to fix it!!
Old Sep 13, 2008 | 09:41 PM
16vEVOIX's Avatar
put the parking brake on
Old Sep 14, 2008 | 07:25 AM
you don't need the parking brake on.
Old Sep 14, 2008 | 09:23 AM
lemmonhead's Avatar
you have to be on a flat surface. Anykind of incline will disable it.
Old Sep 14, 2008 | 09:31 AM
Craig King's Avatar
Are you easing into the gas, or just punching it?
Old Sep 14, 2008 | 09:34 AM
03RRVIII's Avatar
check the switch on the clutch pedal it may not be adjusted properly
Old Sep 14, 2008 | 09:20 PM
Itchy's Avatar
switch? and could you get the limiter if you ease into it or do you have to just punch it?
Old Sep 14, 2008 | 09:27 PM
RedHook's Avatar
Mine works fine, it just has to be completely stopped and the rpm won't go past 5500. mine is an MR though. I don't know if it came on rs
Old Sep 15, 2008 | 10:13 PM
sllt1776's Avatar
i have mine set at 5000. works just fine. just can't be moving at all. if you are moving, it will be considered above 0 speed and then default to what your redline is set too. no need for E-brake and doesn't matter if you slam the pedal or ease into it. I using my tune with EcuFlash
Old Sep 19, 2008 | 08:00 PM
robbunker's Avatar
I have an 06 RS and my limiter works just fine...
except it's set to 6,500rpm for some reason
Old Sep 19, 2008 | 08:20 PM
Smike's Avatar
If its higher than 5000 its been reflashed. It was turned on for all Evos (MR, RS, GSR) from 2005 up. 03/04s have it but it was set beyond the redline.
Check the clutch switch to make sure it gets fully pushed in. Means you need to get upside down in the footwell and move the clutch and make sure it fully pushes the switch down.
Old Sep 20, 2008 | 05:00 PM
jpetro10's Avatar
there is a little pin that the clutch pedal pushes in when depressed, attached to the pin in a sensor or something, sometimes this can come unplugged. Check that, quick question, can you start your car w/o pushing the clutch in?
