driver side tail light issue
Old Sep 16, 2008 | 12:29 PM
NJ_evoIXgsr's Avatar
Veteran: Navy
I've already searched the forum and looking for quick advise on how to determine where the short circuit may be coming from.
I have used a multimeter previously but want to know exactly how I should test my issue.
issue: my driver side parking lights are out. reverse and turn signal work fine
No mod changes
only thing that can be noted was the little hurricane that passed through.
when looking at one of the bulb holder things it looks fairly burnt.
The light will light up randomly while holding the bulbs upward. after putting in back into the housing it doesn't light up.
tested: I have verified with a fuse tester the fuse is fine. I have changed out the bulbs. so i have taken those out the equation. so either a short/relay box if it has one is f*cked. or bad bulb holder thingy.
Old Sep 17, 2008 | 02:32 AM
JDMCT9MR's Avatar
You can try to find another tailight harness. I had the same issue a few months back the problem ended up being a bad harness.
Old Sep 17, 2008 | 08:25 AM
RallyXI's Avatar
I had the same problem in my other car I got mine under warranty
