Headlight Modification Question
Old Oct 9, 2008 | 09:46 AM
asdfasdf128's Avatar
Hello guys. I wanted to know if anyone had removed the amber part of the stock evo headlights and replaced them with clear/white reflectors? I know that evodave removes the amber and blacks everything out on the inside, but I wanted to know if anyone has seen/has pics of the amber part removed and replaced with white/clear reflector.
Old Oct 9, 2008 | 09:54 AM
blackevolution8's Avatar
Just pull the lense apart, take out the amber insert and you'll have a solid chrome headlight. The whole headlight is crhome. The amber is just an insert that pops out.
Old Oct 9, 2008 | 10:08 AM
Yorl8's Avatar
I've replaced the amber part, and painted the upper and lower part of the lower section in flat black. Mine's european, so that used to be the indicator. Changed from indicator to position light, and it looks "almost" like a led-eqqiped audi. Different, at least...
Old Oct 9, 2008 | 11:37 AM
I dont like the evodave look with the bulb exposed.
Old Oct 9, 2008 | 11:38 AM
pics?
Old Oct 9, 2008 | 11:41 AM
Yorl8's Avatar
Gotta take some, just finished the car last week. Also did an air intake on the left one
Old Oct 9, 2008 | 01:07 PM
chaotichoax's Avatar
I don't believe this is legal though
Old Oct 9, 2008 | 03:17 PM
Me either. I bought an evo with them and never liked them. I painted a set on my first evo black all the way around, then put the amber lense back in. It darkened the amber and looked pretty good actually.
Old Oct 9, 2008 | 03:18 PM
If youre headlights are solid chrome, you need to have an amber or red bulb that flashes the turn signal.
Old Oct 9, 2008 | 03:24 PM
boostedtres's Avatar
how hard is it to pull the headlight apart? i know the subie guys bake there headlights, is there an easier way to go about taking this amber part out? thanks guys
Old Oct 9, 2008 | 03:40 PM
Some guys put them in an oven to soften the glue. That idea kind of scares me. I used a heat gun from my work. Slowly heat up the glue and pry the two pieces apart very slowly.
Old Oct 9, 2008 | 03:50 PM
Duh Panda's Avatar
heat gun.... lol like a soldering iron? imma try it
Old Oct 9, 2008 | 03:55 PM
tvbf1's Avatar
No, do not use a soldering iron. The heat gun is like a super hair dryer with temps up too 1000 degrees F.
It's about $25 at Wal-mart.
Old Oct 9, 2008 | 04:25 PM
Dont use a soldering iron. Two completely different things. The gun will allow you to focus the heat on the glue and not the entire lense. Just be careful of your heat levels. If you focus the heat on one spot for too long with a heat gun, you'll melt the plastic.
When youre done, put the two back together and heat the glue up again and push the two together. The glue will bond together. If done right, you wont have any leaking problems.
Old Oct 9, 2008 | 04:27 PM
ROFL, I can just see that guy using a soldering iron
