Fuel leak when fueling?
Old Oct 25, 2008 | 05:25 PM
Nvr2old32's Avatar
Quick question. Everytime I fill the car up, I get some fuel drips right under the gas tank. But after a few seconds, it stops and doesn't leak anymore. Any ideas why it would be doing this. I would have figured if I was leaking fuel, it would be continuous but it only happens when I'm putting gas in the car.
Thanks for your help!
Mike
Old Oct 25, 2008 | 06:29 PM
huevosrancheros's Avatar
get your a$$ under there and check it out with your 2 eyes. If i would have to guess you have a leak somewhere along the fuel tube connecting to your tank. Maybe a bad seal.
IDK
Good Luck finding it
Old Oct 26, 2008 | 12:16 AM
bso's Avatar
bso
Fuel tube and tank is held together by a rubber coupler above the axle. Check factory clamps.
Old Oct 26, 2008 | 08:56 PM
newimportowner's Avatar
I think there is a vent line there too.
Old Oct 27, 2008 | 01:16 AM
emilebazin's Avatar
sound like you have a hole or one of your lines came lose. Any how go to the dealer and have it check. That should be back by your dealer
Old Aug 29, 2013 | 08:40 AM
thetanktowel.co's Avatar
The Tank Towel. com
Protect Your Vehicle with
The Tank Towel
Safely, Cleanly Refill Fuels and Fluids
The Tank Towel is a unique kit designed to protect surrounding areas from splash-back and perpetual dripping when refueling vehicles. The caustic fuel that contact’s painted surfaces damages the clear coat over the paint, and eventually the paint, when wiped off. Gradually the finish will dull and yellow. You also avoid accidentally scratching your paint with the metal nozzle. It can be used to mitigate spillage and dripping when transferring fluids of any liquid dependent machinery: Automobiles, Motorcycles, Trucks, Marine Craft, Tractors, Engine Compartments, ATV’s, Scooters, Lawn Equipment, and Industrial & Commercial Equipment & Machinery.It also has a green factor with regards to boating, by avoiding spilling fuel into and contaminating our waters.
For more information or to make a purchase, visit: thetanktowel.com
God Bless America, thru Jesus Christ
Old Aug 29, 2013 | 08:42 AM
The Tank Towel. com
Mike
The Tank Towel
The Tank Towel is a unique kit designed to protect surrounding areas from splash-back and perpetual dripping when refueling vehicles. The caustic fuel that contact’s painted surfaces damages the clear coat over the paint, and eventually the paint, when wiped off. Gradually the finish will dull and yellow. You also avoid accidentally scratching your paint with the metal nozzle. It can be used to mitigate spillage and dripping when transferring fluids of any liquid dependent machinery: Automobiles, Motorcycles, Trucks, Marine Craft, Tractors, Engine Compartments, ATV’s, Scooters, Lawn Equipment, and Industrial & Commercial Equipment & Machinery.It also has a green factor with regards to boating, by avoiding spilling fuel into and contaminating our waters. Visit: thetanktowel.com
GeorgeP
Northeast Region
May 18, 2017 07:12 PM
hevek
Oct 25, 2012 09:32 AM
BOOSTINAT30PSI
54
Jun 28, 2012 10:27 AM
evodrivesme
Apr 23, 2012 04:31 PM
GSX 911
Aug 9, 2011 08:43 PM
