question about CF hoods
Old Nov 7, 2008 | 05:54 AM
ev0lution9's Avatar
i have a seibon CF hood on my evo and i cant find the right windshield washer squirters to fit would anyone know any that fit??
Old Nov 7, 2008 | 06:10 AM
ev0lution9's Avatar
yea i didnt really care for em inthe beginning but now i just dont like holes in my hood i heard certain honda ones fit but im not sure
Old Nov 7, 2008 | 06:16 AM
Xsubyowner's Avatar
CF washer pissers
If you have your old OEM hood you can transfer them over to the CF hood..thats what I did...used a little super glue to hold them in place...or if you just want to close up the holes go to Pep Boys or Advanced auto parts..and get a firewall plug..its just a flat rubber plug...easily installed ..plus they are like 2 bucks for 6 or 8 count... or go to the junk yard and get them off a regular lancer...
Old Nov 7, 2008 | 06:31 AM
ev0lution9's Avatar
i tried to fit the ones from the OEM hood but it doesnt fit i mean i didnt try super glue i just want to find ones that actually fit
Old Nov 7, 2008 | 06:58 AM
Xsubyowner's Avatar
I had to open the holes a little with a file....all CF parts are inperfect...I have fenders too...they were a real $^#^#$ to install...The OEM ones will fit...they just need a little persuation.
Old Nov 7, 2008 | 07:04 AM
Joshs EVO's Avatar
OK heres the key to getting them to fit. You may need to drill just a little bit. But once you have them in where you want them stick a small nail in through the bottom of the nozzle and that is what holds it down.
If you don't understand PM and I will give you my cell # its really easy if you think about it
Old Nov 7, 2008 | 07:34 AM
ev0lution9's Avatar
thanks for the replies guys im probably going to try and drill a bit to see if i can get them to fit i already tried shaving the plastic off the oem squirters too
Old Nov 7, 2008 | 07:36 AM
EvoFlash's Avatar
I cut a little around the oem squirters to make them fit and now it works perfect.
Old Nov 7, 2008 | 09:26 AM
gsrboi80's Avatar
Yup I filled to make the OEM squirters fit
Old Nov 7, 2008 | 10:33 AM
jackchn152's Avatar
id just skip the washer fluids stuff... dont want holes in the beautiful cf hood
Old Nov 7, 2008 | 03:43 PM
oneofakindtrini's Avatar
ye i strongly agree wit this dude. o well. its ur car.
Old Nov 7, 2008 | 03:49 PM
jaysonmyfeet07's Avatar
same probem here. i still dont have mines on.
Old Nov 7, 2008 | 11:08 PM
ev0lution9's Avatar
holes are alrede in there man
Old Nov 8, 2008 | 12:09 AM
AIEvo9MR's Avatar
The holes were pre-drilled and only one fit in mine. I just drive without them since I throw out the reservoir.
Old Nov 8, 2008 | 09:50 AM
MasterNater's Avatar
A dremel with a sanding cone/bit is your best friend. 2 minutes with that, and I had both washer nozzles installed and working. Good Luck.
