Quantify Benefit of Rear Wing
The way i see it. Down the 1/4 mile you're either not fast enough to see the effect. Or if you are that fast down the 1320 then you probably have enough power to not give a sh*& about a little bit of drag.
yea i had mine off for like a day and u can def feel the difference. id recomend taking it off and get the feel then decide for yourself. the only real benifit i noticed was quieter ride but lik i said i put mine back one.
The wing is there for a reason, to provide downforce, but at the same time you are not going to notice that much of a difference driving at highway speeds. You should only notice it when travel at 100+mph. Check out this video, it a member from MLR doing a high speed run in a standing mile, at the end of the run he lifts his foot off the accelerator to slow down and the car goes into a spin at 183mph. He had taken the spoiler off for this run to try and get a few more mph in the run but spun because of it not being there.
http://uk.youtube.com/watch?v=-0oJ2wQiu2Y
Vortex gen doc from mitsu:
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
There is some data in there about the wing and I believe there is a doc in that section specifically about the wing also, but I can't find it right now. There is a doc on the gourney flap and zero lift stuff somewhere also.
Either way, tons of threads on this. Se....
I'm not finding that particular tech doc through the search.
Rexpeed makes a note about mitsu testing for the gurney flap that says 14kg (30.86lb) more downforce at 180km(112mph)
here: https://www.evolutionm.net/forums/sh...98&postcount=1
Diffusers can't create downforce, they just remove lift.
Technically there is no such thing in physics as "downforce", the term is actually negative lift. Maybe that helps?
If you draw a free body diagram... it would be adding a normal force to the car (downforce) Rear diffusors in every sense of the word generate downforce.
Revived from the dead. need to get back to work. sorry :P
