EVO 6 GSR 2.3 build
Old Nov 17, 2008 | 09:35 AM
chrisdebruin's Avatar
EVO 6 GSR 2.3 build
Hi Guys
I own a EVO 6 GSR and recently built my engine with Stroker comp pistons, rods and a stroker crank bringing the CC to 2.4Lt.The cams are Blitz light weight with a little delayed lift.The ECU is a Reflashed evo 8 ecu with a carbon copy Ralliart program.The turbo is standard evo 6 with standard wastegate.
The problem is with the Apexi AVCR i am only getting 1.2 bar boost on 1st and 2nd gear and 1.5 bar boost on the rest of the gears.Can somebody help and tell me how i can increase the boost to spike to max boost and then taper it down.When the vaccum hose is removed and we do a run max boost is 1.7 bar
Also the AVCR is showing a negative boost when the engine is switched off and on ACC mode.
Can somebody advise pls
Thanks
Chris
Old Nov 17, 2008 | 09:41 AM
EvoBoostIX's Avatar
maybe a small wastegate leak? what is the AVCR set at?
Old Nov 17, 2008 | 09:48 AM
chaotichoax's Avatar
you already posted a thread it's in evo engine/turbo/drivetrain
https://www.evolutionm.net/forums/sh...d.php?t=382030
closed...
