Lights not turning off
Old Nov 22, 2008 | 08:17 AM
Joeekrub's Avatar
the thing that is weird with my car that has randomly developed recently is that when i turn the headlights off, the headlight symbol on the dash dims but does not cut off completly (this causes my MR gauge lights not to go off and my aftermarket radio impossible to see). this is causing the yellow corner lights not to turn off which is also causing my rear brake lights to not get bright again like they should in the daytime.......whats causing this? bad relay?
Old Nov 22, 2008 | 08:20 AM
Joeekrub's Avatar
got it
https://www.evolutionm.net/forums/sh...d.php?t=323902
Silver06evo9mr's Avatar
u might have the water leak problem. check the junction box by your feet behind the black plastic panel. if wires are corroded your in trouble.
Old Nov 22, 2008 | 08:23 AM
yup that it. had my wireing harnesses replaced under warrenty too
Old Nov 22, 2008 | 08:24 AM
gsrboi80's Avatar
Not in trouble just need to get out that old solder gun
What a friggin thing for mitsu to do. Bastards
Fixed yours up a while ago right Silver06evo9mr
