Weight Reduction.
Old Aug 19, 2005 | 02:00 AM
  #46
trinydex's Avatar
Originally Posted by DrMerl
Ok, I fully understand the realities of weight vs HP....but with all that money you've spent on exotic Titanium coilovers (was the stock handling that bad?) and removing functional aerodynamics, spending thousands on rims when the stockers are at 18lbs (could save 5 lbs each by going with Volk CE28N and retain strength)....etc, etc
What is this going to yield at the track? What will a 200lb lighter EVO do over an EVO that has simply upped boost, or changed ECU or even exhaust?
I can see the spare removal (keep a can of fix flat around), but everything else on this car is a bit silly unless you're gonna be a trailer queen.
Those are my heavy opinions =)
stock wheels are not 18 pounds... unless you're on mars, the stock wheels advertised weight is balogne they're more like 22 so switching to a real life 14 pound ce28 will save you quite a bit... AND get you more width on your wheel.
at the track... they usually say... 100 pounds is a second. that's nothin' to sneeze at.
Originally Posted by joeycoates
The stock hood is 22 or 23 lbs. I read where someone went to put on a carbon fiber hood and actually gained a pound because the stock one is already aluminum.
this is totally true which is why it's imparative for anyone doing real hardcore wieght reduction to get genuine dry carbon parts and not the wet carbon pieces. a dry carbon fiber hood is about 7-11 pounds (depending on who you get it from)... that's nothing' to sneeze at either cuz that's coming off the heavy end of the car at hte highest point! same goes for trunk if you get a dry carbon unit.
i acutally have a thread somewehre old and it has a lotta weights on stuff.
carbon fiber fenders are available.... and so are aluminum roofs.
actually if you want a comprehensive list of the lightest full trim street car you can get. here it is (these are all conservative estimates and i'll cite some examples).
two race buckets will actually only prolly save you 5-10 pounds each, the stock seats are pretty darn light unfortunately. (fiberglass seats from sparco with aluminum side mounts and seat base from rmr) cf will obviously save you lots more, up to 15 pounds per seat.
two cf f1 style mirrors will save you maybe 1 pound or 2 for the pair.
a cf hood can save you 7 pounds if you get a nice one (all american racing or cwest cf).
cf trunk can save you 11 pounds (all american racing or cwest cf)
with wings you are just trading.
a ti catback will save you 30 pounds (bushcur claimed a savings of 26 pounds for his exhaust and the ti systems are about 6 or so pounds lighter than his) (greddy ti is prolly teh lightest of the bunch, maybe amuse, but i hear it's a pound heavier)
removing your seatbelt and trading for a harness is about equal (for a lightweight harness) (latest sparco competition)
taking out the spare has already been discussed to remove 40 or so pounds
removing the trunk interior barely saves you 10
getting the lightest wheel possible that is a decent size for the evo (gramlight 57f 17x8.5) will give you about 10 pounds per wheel.
getting the stoptech front kit will save you almost 13 pounds a piece total of 26 in front
replacing your rear rotors with two pieces that are available can save you a total of about 12
replacing your suspension with coilovers usually saves you some (someone fill in a number)
removing your front strut bar and replacing with a ti unit will save you about 10.
replacing your battery with a mini unit will get save you about 30 (the trays are lighter and you remove a lotta hardware)
replacing your stock air box with an hks unit will save you more than 5 pounds.
replacing your front bumper with a jdm style bumper that removes the crash beam will get you 20-30 pounds depending on how heavy of a bumper you get.
for the rear i believe 10-20 is just as fair.
replacing your lug nuts with aluminum ones from volk can save you up to 2 pounds per wheel totally 8 pounds.
tires are most likely a negative adding weight.
replacing the steel tie bars with aluminum units is most likely a trade.
taking out your roof and puttin in an mr unit will save you 15 pounds if you had a normal steel roof and up to 65 pounds if you had a sunroof.
carbon fiber fenders will prolly save you 15 pounds total.
intercooler piping can save you 2 pounds for lower and upper (replacing with aluminum)
replacing the cast header with a ebay mani will prolly save you 15 or more pounds.
all this talk is without draining any fluids... without taking any interior out, without compromising anything.
Old Aug 19, 2005 | 02:21 AM
  #47
negativeB's Avatar
Originally Posted by veritech137
The best weight reduction....Get on a treadmill and start joggin!!!
Originally Posted by celerilux
Everyone thinks they're a comedian...
this is actually a great way to take weight off your car. remember, it doesn't run without you in it. and how many fat racecar drivers do you see? what advantage does danica patrick have over other racers?
Old Aug 19, 2005 | 05:11 AM
  #48
The_Predat0r's Avatar
a pound? impossible! My friend installed a carbon fiber hood and it weighs almost double than the stock! The stock one is damn light! Dont touch it!
Old Aug 19, 2005 | 05:41 AM
  #49
justchil's Avatar
I don't think I've seen anyone say anything about removing AC and PS?
Old Aug 19, 2005 | 05:43 AM
  #50
nubby's Avatar
Registered User
I don't think you're going to save 45 pounds putting in racing shells. I posted this in another thread:
The OEM driver's seat, with all bracketry and the seat belt receiver weighs in at 37.4 lbs. I weighed this on a digital shipping scale, so it should be pretty accurate.
Lighter than I thought the whole assembly would be.
I also weighed a Sparco Evo racing shell with aluminum side mounts and Evo base, which is 25.6 lbs.
So you're looking at more like 24lbs putting in racing shells.
This is a fiberglass seat. Obviously you could save some extra weight going with carbon/kevlar, but $4000 for a pair of seats seems a little steep to me for the weight savings you get.
Old Aug 19, 2005 | 08:08 AM
  #51
Silk's Avatar
What about that evaporative emissions control thingy located on the drivers side right behind the rear wheel. Looks pretty bulky, but would it be safe to remove.
Old Aug 24, 2005 | 07:35 AM
  #52
Kee1pride's Avatar
anyone have any idea how much stock BBS MR wheels weigh?
Old Aug 24, 2005 | 07:44 AM
  #53
fromWRXtoEVO's Avatar
Originally Posted by Mister2zx3
I'm creating a list of stock weight parts and aftermarket lighter parts. If you have any facts or top secret info you're willing to share with your evolutionm friends on stock or aftermarket bits.
Who knows the wieght on stock:
Rims
Tires
Hood
Trunk
Brake Rotors
Bumper Supports
anything else?
I know some facts for sure:
my friend'ss greddy full Titanium cat back weights only 8-9 pounds.
The MR wheels with stock tires weights 43LBS
The Buschur Deluxe upper IC pipe with mini battery saves your aound 24lbs
Old Aug 24, 2005 | 09:09 AM
  #54
MR 600's Avatar
You can get 6-7 lb carbon fiber seats. (not including mounts)
Old Aug 24, 2005 | 09:11 AM
  #55
nosbrody's Avatar
volk makes the lightest wheels for evos i think..
Old Sep 8, 2005 | 09:22 PM
  #56
Blue By You Evo's Avatar
if your building a track car, you can pull the radio and speakers, just bring your ipod with u and put the ear pieces under your helmet.....also those lightweight windows help too, not sure if this stuff was mentioned or not...
Old Sep 8, 2005 | 09:31 PM
  #57
evil-ution's Avatar
I wonder how fast a stock evo thats lightend, compared to a modified evo full weight. For performance upgrades, strip the car, save the money.
Old Sep 8, 2005 | 09:51 PM
  #58
WickedWhiteRS's Avatar
Buy an RS. Pull out everything you can take out. Replace the glass, call it a day.
Old Sep 9, 2005 | 03:08 AM
  #59
BMo's Avatar
BMo
Get rid of the IC sprayer unit. That thing is useless anyway.
Old Sep 9, 2005 | 05:42 AM
  #60
mdosu's Avatar
Brake Rotors
ooo I know this...I'll weigh it for you after I get home from work...
I just swapped mine out for Stoptech rotors, and the Stoptechs "felt" about 2 to 3 pounds lighter each...
you can also take your backseat out, that'll save a lot of weight.
