What tool are you using for Spot Weld Removal
Old Dec 7, 2008 | 12:25 PM
RABYRAB's Avatar
I am looking at a couple of different ones and I was wondering which one are people using?
Old Dec 7, 2008 | 05:48 PM
Evo8Emperor's Avatar
Spot welds you can either drill through if its like a flat seem weld or if you have a bigger spot weld cut a X into the weld then air chisel it off.
Old Dec 7, 2008 | 06:50 PM
lhausi's Avatar
I just use the drill bit you can buy that's specifically for spot welds,you can set it to how deep you want it to penetrate the metal and drill them all out withing seconds. Great bit and its like 25 bucks. And if you hit them dead on it'll pop right off, otherwise an air chisel will help when you need to remove that last little piece
Old Dec 7, 2008 | 06:58 PM
Abizzle's Avatar
You can get the bit from Snap on, its got a little bit inside of another bit and it drills a mini pilot hole and also drills the spotweld out, but the easy tool is this thing that wraps around whatever your drilling and it puts pressure on the spot weld so you dont have to sit there pushing your drill, it does it all for you.... The only draw back is the price, get ready to spend 3-600 bucks...
Old Dec 7, 2008 | 07:06 PM
hotrod2448's Avatar
I've used rota-broaches in the past with good results.
http://www.handsontools.com/Blair%20...te=google_base
