What Gains Should I Get?
Old Dec 13, 2008 | 05:53 PM
monkey_187's Avatar
What gains should I get with the following mods:
Fujita F5 Intake w/ all ICP's
A'pexi full race exhaust w/ down pipe
HKS 272 intake & exhaust cams
Megan Racing Manifold
HKS Boost Controler
Walbro 255 Fuel Pump
AMS FMIC
What other mods will I need or should I get to reach 400hp?
EDIT:Would a Apexi AFC Neo Air Fuel Controller help me see gains and will it work without problems with th HKS EVC VI?
Old Dec 13, 2008 | 06:09 PM
BenJ's Avatar
I wouldn't worry about getting the megan manifold seeing as though the gains would be the same as a ported stock manifold and it will eventually crack on you. Do you have 93 in Chicago? If so I would say that you would be in the 340 range on a dynojet.
Old Dec 13, 2008 | 06:16 PM
monkey_187's Avatar
Yes we have 93 in Chicago, the manifold is already installed in the vehicle. I am in Iraq right now and will return home soon. I want to get some ideas as to what type of gains im looking at.
Old Dec 13, 2008 | 06:36 PM
awdwannabe's Avatar
if your looking for 400 on pump only, then a bigger turbo will be needed without question.
Old Dec 13, 2008 | 06:46 PM
monkey_187's Avatar
I want to get as close as possible without changing the turbo right now
Old Dec 13, 2008 | 06:50 PM
evo4life400's Avatar
then throw some meth in there and run really high boost but its really hard for the evo 8 turbo to pump that much hp out. get a cheap used 9 turbo and meth i would say if you wanna be at 400whp. id say with ur mods u will be at 330-350
Old Dec 14, 2008 | 12:11 AM
detroit pistins's Avatar
what psi were u thinking of running at?
Old Dec 14, 2008 | 01:21 AM
monkey_187's Avatar
Around 20 if I can without any problems.
Old Dec 14, 2008 | 11:59 AM
I am very experienced with dyno numbers but 20 seems to be low however if u do obtain those numbers on 20 psi with 93 octain then i thinks ur mods should bea sticky
goodluck,
Old Dec 14, 2008 | 07:42 PM
monkey_187's Avatar
goodluck,
What should I run then? What is a good number to run on a stock turbo for the most possible gains?
Old Dec 14, 2008 | 08:06 PM
would luv to u give u the magic number man but i really don't know myself , iam learning and benefiting from ur thread as well, but looking at some of the other set ups and dyno numbers on here , it seems like around 23psi is a safe range that would put u around 350whp based on a flash, intake, tbe, and some ic pipings.
Old Dec 14, 2008 | 08:50 PM
BenJ's Avatar
On a stock turbo on 93 octane you can fairly high depending on the competency of your tuner. Just be sure that anything over 24-25 psi you install headstuds. I've seen evos on the stock turbo on 93 going up as far as 27 psi, maybe even higher. If you can, go E85; I'm currently tuned on E85 and on my stock IX turbo I'm making 425/400 at 29 psi.
Old Dec 14, 2008 | 09:10 PM
have u changed any of the internals?
Old Dec 14, 2008 | 09:46 PM
BenJ's Avatar
nope stock internals are good until around 500whp
Old Dec 14, 2008 | 09:49 PM
wow that's sweet! iam betting that's cuz ur using E85 correct? could it be done with Meth? sorry if iam drifting off topic but i was just wondering.
thanks,
