Evo headlight adjustment???
Old Sep 15, 2003 | 01:12 AM
trev0006's Avatar
Does anyone know how to adjust the Evo 8 headlights so the beans point a little higher? After I lowered the car the front seems to be pointing down more then stock and the beam of light points lower also, I was wondering if there is a screw that adjusts the headlights from nside the engine bay. ( I have the light switch adjustment from inside the cockpit on 0 ) but still the beam is low for me.
Thanks
Old Sep 15, 2003 | 01:16 AM
LuvmyEvo's Avatar
IMO
If you find out how to do it let me know, mine are too low from the factory on 0. since they are motorized I hope there is an adjustment. You would think there would be, but who knows.
Old Sep 15, 2003 | 08:24 AM
Boosted's Avatar
theres no way ive found, there is a screw for the HID's but its already set at the highest point from the factory...
Old Sep 15, 2003 | 08:28 AM
PocketAces's Avatar
There is a gear behind each headlight that you have to use a flat head screw driver to turn...very difficult to do but attainable. Do a search and you will find several LONG threads on this process.
Old Sep 15, 2003 | 08:32 AM
camdog17's Avatar
My suggestion would be to check the repair manual, I'm sure you can download it somewhere...my $.02
Old Sep 15, 2003 | 08:59 AM
chinalfr's Avatar
Instead of using flat head screwdriver, use a 10mm socket. It works much more better than screwdriver. Search the forum and you'll find tons of info.
I'm not sure if you need turn it clockwise or wise verse.
Old Sep 15, 2003 | 09:03 AM
nastea's Avatar
yeah, its there but good luck doing it...i had problems and i've tried many times
Old Sep 15, 2003 | 09:21 AM
res04's Avatar
I would have the dealer do it next time its in. they have the alignment process down and can do it right, more than likley on their dime too.
Old Sep 15, 2003 | 09:27 AM
sccavee's Avatar
Dealers are not allowed to change the headlight position due to liability issues if they do so.
Old Sep 15, 2003 | 09:43 AM
res04's Avatar
Im amazed that this is the case. If the lights are out of alignment on a stock care for example you would think they would be required to adjust it - it should be tested prior to delivery.
Old Sep 15, 2003 | 09:45 AM
sccavee's Avatar
All the settings from the factory are low on the Evo. The HID lights are very bright and if the have them to high from the factory they can run into all kinds of issues.
Old Sep 25, 2003 | 10:46 PM
skbydoo's Avatar
Use a 10mm screwdriver and dial the dealer. Mine are way low and i haven't even lowered the car.
Old Sep 26, 2003 | 01:50 AM
EvoInSoCal's Avatar
yup, two dealerships out here have already told me that they cannot adjust the headlights any higher, since it's at factory spec right now. Mitsu really messed this one up, cus in all honesty, we can just set the beams lower if need be with the elctric settings (even though i know it's to level off the beam due to various loads etc...)
it does suck, and it's a pain to adjust as well.
Old Sep 26, 2003 | 05:29 AM
Fireball's Avatar
They ARE adjustable. I HAVE adjusted mine. It's just really tricky. I set mine where the 0 used to be, is now level 2. So I have 2 more steps higher. I usually keep it at 1.
There are a couple threads with pictures on it. It is adjustable with the 10mm phillips screwdriver and the gear looking thing right behind the lights. If a dealer says that they can't adjust them, that means they just won't. It IS possible.
Old Sep 26, 2003 | 09:52 AM
jojo's Avatar
I too have adjusted mine. I have posted pictures before on where it is to adjust.
