evo ix RS power windows
Old Feb 23, 2009 | 07:56 PM
superflyevo's Avatar
does anyone know where to get bolt in power windows for for the RS? for a matter of fact the rest of the power things locks ect.
Old Feb 23, 2009 | 08:07 PM
Juan Martinez's Avatar
If you could find someone that has power options that wants to save weight and downgrade, he might trade you. You'll probably need door panels, acutators, wiring, and some relays/fuses. I've done this once on an rs Eclipse. It was really easy.
Old Feb 23, 2009 | 08:31 PM
evo_tiago's Avatar
Some body wants to trade power windows to ures.. Check Private sale section
Old Feb 23, 2009 | 09:03 PM
good idea but i swear a cupple years back someone was making a full kit
Old Feb 23, 2009 | 10:04 PM
Evolution IVGSR's Avatar
You may have to swap out your entire doors and know that you will also have to do the wiring for it too... I think that the mounting for the motor is different, but it may work? wont know untill you try tho
Old Feb 24, 2009 | 01:49 AM
vipers's Avatar
well.. i guess i can chime in as i have an RS and i did a full front window swap...... everything is a direct swap, there is no modifying or cutting of the front windows... i just found a thread of someone who wanted to swap.. or start your own thread.... all youll need for the swap is the motor, power window rails, door panels, wiring harness, and i think that was it.... it took me a few hours to do, but wasnt painstaking or anything... now the rear is a completley different animal, and im not gonna cut into my b-pillar..so i left them alone if you need any more help or any questions just lemme know
Old Feb 24, 2009 | 08:19 AM
awesome.. so i jus run all the wiring to the fuse box? what kind of cutting needs to be done to the b piller
Old Feb 24, 2009 | 08:23 AM
Lancerguy'03's Avatar
another idea is the 02-03 lancers have the same front doors as Evo8/9s, so that means same power windows.
Old Feb 24, 2009 | 09:59 AM
Celica2EVO's Avatar
I might be willing to do the swap, shoot me a PM about it!
Old Feb 24, 2009 | 11:05 AM
well i havent bought the car yet, still thinking about it . its between a 03 that is fullyloaded with 30k miles all stock. or this IX rs that is in the F/S thread on here.
https://www.evolutionm.net/forums/sa...-15-500-a.html
Old Feb 25, 2009 | 11:23 AM
yoteru's Avatar
why buy an RS if you want power windows? doesnt that defeat the purpose of the RS?
Old Feb 25, 2009 | 12:54 PM
vipers's Avatar
well not exactly.... you have to run the wiring through the door jambs and they simply plug into the harness under the dash.... just make sure to add the fuse for the power windows.. a simple mistake that cost me an hour of searching...lmao.. and as for the b-pillar...... the RS doesnt have a single wire that goes to the back door, so there was never a hole cut into the b-pillar to feed wires through..so youll have to cut an oval shaped hole and add the rubber wire cover that goes from the pillar to the door... and also, youll either have to cut and splice the wiring, or add the harness that goes basically from the dash all the way to the back of the car ..its not a simple plug and play like the front... thats why i left it alone..lol
NO! there are just some amenities that i enjoy having, and the RS has alot more to them then just manual windows
Old Feb 25, 2009 | 01:43 PM
JJsEvo8's Avatar
+1. If you want more, save yourself the time and upgrade to the GSR or MR.
Old Feb 27, 2009 | 05:20 AM
i do want more but this rs is a realy good deal
Old Feb 27, 2009 | 06:13 AM
gsrboi80's Avatar
As stated everything to the front bolts right up. I did the PDL swap on my EX's RS. Granted I wired it up to an aftermarket alarm but it was a piece of cake
