Car wont start
Old Mar 7, 2009 | 09:13 AM
evillancer06's Avatar
Veteran: Navy
checked all of the fuses and they all check good. what other relay other than starter relay controls ignition and lights and window power.
Old Mar 7, 2009 | 06:13 PM
20gmr's Avatar
Im sure your tired of hearing check fuses but did you look at the ones on the actual terminals of the battery?
Old Mar 7, 2009 | 06:39 PM
Sansone's Avatar
Are the battery terminals tight? lol.... But seriously the relay seems to fit this the best. My buddy popped one of his on his Evo 8 from plugging in the radio with the car on.
Old Mar 7, 2009 | 07:27 PM
heavens turbo's Avatar
realistically, there would not be a relay that controls the turn signals AND the ignition. but, to put your mind at ease, swap relays with a known good one in your car. if that doesnt work, recheck fuses with a testlight. if you still have problems, you may have tapped into a wrong wire or something. time to get the wiring diagrams. good luck. or like dude said, could be a key issue.
Old Mar 7, 2009 | 08:03 PM
evokid511's Avatar
i think someone mentioned it earlier that if you put the key in and the green light comes on then you tripped the security sensor! now how you get that fixed i have no idea sorry
Old Mar 7, 2009 | 11:45 PM
koey03's Avatar
might be fuses or relay? check the fuse box
Old Mar 8, 2009 | 04:02 PM
Veteran: Navy
thanks for all of the advice guys. i figured it out. if anyone ever comes across this problem it was the green 40 amp fuse in the engine bay. i checked the ones i could, and that one looked good. bridge and everything looked good but light never came on for it so i swapped it and BAM i got power. thanks again guys.
Old Mar 8, 2009 | 06:41 PM
bboy_RES's Avatar
i had a feeling it was a fuse cause the same thing happened to me when i was installed my remote start. congrats on solving the problem.
