What should i buy im @ 65k and need to freshin up
Im over the 60k service and I dont have the book, what should i do to freshin up my car. I think i need to get new belts and maybe a water pump. Will some one fill me in on whats due.
The car has fmic, full piping, 3in turboback no cat, intake, tune 93 octane
If any venders want to shoot me ideas on what to do feel free. I need injectors, fuel pump, headstuds, kevlar timing serpentine and balance belts and spark plugs.
30K,60k,90k Miles Service
Mobil 1 Synthetic 10W-30 Oil W/ OEM Oil filter and Crush Washer
Tranny Fluid Flush: Choice of OEM or Redline MT90/MTL/BG Synchro Shift
Transfer Case Fluid Change: OEM Diaqueen
Rear Diff Fluid Change: OEM Diaqueen
Coolant Flush
Spark Plug Change: Denso Iridium / Stock Heat Range or 1-Step Colder
Brake Fluid Flush: Valvoline Synthetic or for Motul RBF600
Check and Top Off All Fluid
Tire Rotation , Check Pressure & Retoruqe Wheels
Inspect Brakes, Belts, Oil leaks and ETC....
Bleed ACD Fluid for 05+EVO
Also... Every 60K miles, you should change out your Timing belt and Water Pump.
Which usually consists of
OEM Timing Belt
OEM Timing Belt Tensioner
OEM Balancer Belt
OEM Balancer Belt Tensioner
OEM Water Pump
OEM Thermostat
OEM Idler Pulley #1
OEM Idler Pulley #2
OEM Crank Seals
OEM Access. Belt
Inspect Brakes
Coolant Flush
OEM Timing Belt
OEM Balancer Belt
OEM Water Pump
OEM Thermostat
OEM Idler Pulley #1
OEM Idler Pulley #2
OEM Crank Seals
OEM Access. Belt
Inspect Brakes
Coolant Flush
OEM Timing Belt
OEM Balancer Belt
OEM Water Pump
OEM Thermostat
OEM Idler Pulley #1
OEM Idler Pulley #2
OEM Crank Seals
OEM Access. Belt
Inspect Brakes
Coolant Flush
OEM Timing Belt
OEM Balancer Belt
OEM Water Pump
OEM Thermostat
OEM Idler Pulley #1
OEM Idler Pulley #2
OEM Crank Seals
OEM Access. Belt
Inspect Brakes
OEM Timing Belt
OEM Balancer Belt
OEM Water Pump
OEM Thermostat
OEM Idler Pulley #1
OEM Idler Pulley #2
OEM Crank Seals
OEM Access. Belt
Inspect Brakes
OEM Timing Belt
OEM Balancer Belt
OEM Water Pump
OEM Thermostat
OEM Idler Pulley #1
OEM Idler Pulley #2
OEM Crank Seals
OEM Access. Belt
Inspect Brakes
Since you're in there change the water pump too. Get it out of the way. If your pump starts to go after the t belt job then you have to take the t belt off again to put the pump in. Double work you know.
Motul fluid, although good, does not last very long as it is highly hygroscopic. A better bet is the ATE Super Racing fluid. Put it in and forget it for 2 years. ATE is asl ocheaper than the Motul 600 stuff.
