Startup Clunk ?
Old May 19, 2009 | 12:59 AM
sdfontanini's Avatar
Startup Clunk ?
every now and again i've been getting a clunk noise right on startup. car runs well, just concerned w the noise?
noticed my power steering pulley is sqeeking lately, and it almost looks like my crank pulley has a little wobble to it. other than that car runs perfect.
any ideas?
Old May 19, 2009 | 07:29 AM
After further inspection it looks like the power steering pump pulley is probably going. It has a slight wobble to it and I think it's effecting my main crank pulley.
Old May 19, 2009 | 05:43 PM
EatSleepBoost's Avatar
iv had my power steering pump replaced before due to lack of assist not due to wobble. so idk about that. but as far as clunk mine does it quite often. what u gotta do is figure out a way to make it do it every time. mine would do it if u let the cluch out kinda quick for a split second so the car barely moves at a stop. then you have somebody else sittin under ur hood holding onto ur different mounts to feel which one is doing it.
the one that was clunking on mine was the lower "dogbone" one that is located kinda under the intake mani. i bet u just gotta tighten a mount up a little
