EGR flow insufficient code
Old May 30, 2009 | 11:25 AM
Venividivichi00's Avatar
i had my clutch done and 50 miles later i got this code what could cause this idk if it has to do with the clutch or flywheel or possibly has to do with the fact that the car was ripped apart any direction would be nice?
Old May 30, 2009 | 11:27 AM
dsmfan95's Avatar
Check the vacuum line that runs to it, you might have blown it off. If you can, get back in there and zip tie it.
Old May 30, 2009 | 12:04 PM
EatSleepBoost's Avatar
lol. my friend had the exact same problem right after clutch install. reach down under your throttle body and make sure your vac lines are connected. i bet you will find one not connected
ssteve's Avatar
Yeah I actually had the same thing but it was the hose on the solenoid that blew off, not the egr... Btw anyone know what that solenoid does?
Old May 30, 2009 | 01:47 PM
evoterp's Avatar
i had a similar issue with this right after a clutch install. Except all vac lines were connected. If they are connected, pull them off and make sure the nipple is still intact. It turned out that mine was crushed.
Old May 30, 2009 | 08:46 PM
alright guys thanks ill check it out tomorrow
Old May 30, 2009 | 11:25 PM
555R's Avatar
check that line
i had that happen after dynoing uo to 35 psi
zip tie it
