mounting gauges?
Old Jun 28, 2009 | 10:32 AM
cec12789's Avatar
mounting gauges?
before i ordered the gauges i was wondering i was thinking about having them mounted on the dash like in the middle so i was wondering would i beable to drill holes in the dash to put the gauges there or is that iffy? Like is there another way i could do it or? thanks
Old Jun 28, 2009 | 11:04 AM
aeroweenie's Avatar
you can relocate the radio to where the cubby is, then mount up to three gauges in the stock radio position. 42draftdesigns and others sell mounting plates for this. The radio relocation kit is from Mitsu. Search, there are lots of threads with pix of this.
Old Jun 28, 2009 | 11:31 AM
tweaker41's Avatar
What gauges do you plan on ordering? 52mm/60mm? You can check mitsubishiparts.net and get a radio relocation kit and maybe get the HVAC panel with gauge cutoffs from Gruppe-S or something.
http://www.mitsubishiparts.net/catal...ction=588#1525
http://www.gruppe-s.com/Evo/evoint1.htm
Old Jun 28, 2009 | 11:37 AM
chaotichoax's Avatar
or check out rexpeed's dash solution
Old Jun 28, 2009 | 11:09 PM
MINO's Avatar
Personally, I prefer steering column mounts. although it's limited to 2 gauges, I find most street driven turbocharged cars need only egt and boost. Plus it's a simpler install.
The radio relocation is an odd line of sight and adds more parts with moving the stereo. Not my favorite.
The dash pods are great for people that have track or show cars. Be sure you know EXACTLY what gauges you want to use in it because that double sided tape "should" be replaced every time you want to change something. I've seen them come flying off in hi g situations. With electric gauges, just one wire will be sticking out. I wouldn't drill a hole in the dash for the wire if you ever plan to sell the car later down the road.
Old Jun 29, 2009 | 03:55 AM
AznEvoIX's Avatar
I use A-Pillar mounts on mine. Wires are hidden and a easier install for me.
