Prosport Wideband
Old Jul 7, 2009 | 03:33 PM
D-Mon3y69's Avatar
Prosport Wideband
Hey guys i'm looking for info on the prosport wideband. The good and bad. I'm talking to the people who have experience with them. How accurate are they? Any problems with them? I'm asking cause i can't really find that much info on here. Maybe i'm searching wrong, idk. Any info would be appreciated.
Old Jul 7, 2009 | 11:06 PM
D-Mon3y69's Avatar
Come on someone, anyone..
Old Jul 8, 2009 | 12:55 AM
Toxin's Avatar
If you want a wideband that shows you a value while you drive, it's probably fine just like any other prosport gauge. It'll give you an informative reading. If you want to use the wideband for reasons that 99.9% of the people use them (tuning), then I'd suggest you look into one of the evoscan supported widebands (Innovate,Zeitronix,AEM).
Hope it helps.
Old Jul 8, 2009 | 06:28 AM
gsrboi80's Avatar
Things to look at would be the sensor that prosport uses. As far as logging as long as it has a 0-5V analog output it can be pinned directly to the ECU and log away bro.
Easy easy
Old Jul 8, 2009 | 10:56 AM
D-Mon3y69's Avatar
It says it uses the Bosch wideband O2 sensor -5 wire heated LSU 4.9
Idk about the logging tho
Old Jul 8, 2009 | 04:57 PM
Fast_Freddie's Avatar
Veteran: Navy
Pretty sure it DOES NOT have an output...
Old Jul 8, 2009 | 05:29 PM
D-Mon3y69's Avatar
ya it doesn't i found out sadly, guess i'll try to find something else that is accurate, looks the same as the other prosports, and has output
SmurfZilla
Apr 5, 2013 02:14 PM
beasters
Dec 20, 2012 03:05 PM
GodRealm06
Jul 28, 2012 06:26 AM
bigben
Mar 4, 2012 03:06 PM
03Ev0luti0n
Jun 30, 2010 09:25 PM
