How to get 500whp/500wtq?????!!!
Old Jul 10, 2009 | 08:12 AM
Nomad4g63's Avatar
Question How to get 500whp/500wtq?????!!!
I'm currently running the Fp Red turbo and know 500tq is very hard to accomplish on this turbo. I'm currently on stock ecu and stock motor on 93 oct
I plan on upgrading to AEM and building motor to 2.0 or 2.3l and adding meth. Wanna know what turbo u guys recommend to run to accomplish my goal unless u think the red can do it
Old Jul 10, 2009 | 10:45 AM
binh's Avatar
500 wtq with 500whp? You'll def need to go to a 2.0.
Anyhow you posted in the wrong section. This is dyno tuning and RESULTS.
Old Jul 10, 2009 | 12:01 PM
Nomad4g63's Avatar
Tuners usually view and post on this section, and they have seen what can make 500/500 setup, so i think this is the right section
Old Jul 10, 2009 | 01:37 PM
EvoJoeIX's Avatar
you need nawwwssss.... 2 of the big ones
Old Jul 10, 2009 | 01:38 PM
TheDream's Avatar
2.3 E85, you do not need EMS, speed density is where it is at.
Import Junky's Avatar
302 small block with a Procharger will get you there.
Old Jul 10, 2009 | 01:41 PM
Boost3dxEvO's Avatar
LMAO, post of the year!!!
OP:
Keep the red, get every possible upgrade you can do (including all of the porting, like hotside, manifold, etc), e85 or race gas... high boost.. Look at David Buschur's Project White 2.3 Red on stock ecu AND stock maf.. it trapped 138!
Old Jul 10, 2009 | 02:08 PM
SmurfZilla's Avatar
Like poster above.
Good cams
E85 or Meth
Good quality bolt on's
should be able to hit 500 easily with out having to stroke the motor.
Old Jul 10, 2009 | 02:13 PM
Kevin@MellonRacing's Avatar
There's no need for the EMS, stick with the stock ecu.
Old Jul 10, 2009 | 02:37 PM
chaotichoax's Avatar
search for more
closed...
