Reverse Lights
Old Aug 2, 2009 | 09:31 AM
spiderseth's Avatar
Reverse Lights
Ok well inspection is coming up and my reverse lights dont work yes I have checked the bulbs and fuses. Anyone had this happen?
Old Aug 2, 2009 | 10:02 AM
mini_evo's Avatar
I have never had this problem personally.... but you might want to take your center console out and check the reverse light switch. When you shift to reverse there is a switch that comes in contact with the shifter base and closes a circuit to turn the lights on. Use a multimeter to see if the switch is good or not and see how much resistance it has when the circuit is closed. It should have close to 0 ohm resistance IIRC. If it passes this test, make sure it is adjusted properly.
Old Aug 2, 2009 | 12:34 PM
mitsuclipsegsx's Avatar
What he said, maybe its loose.
Old Aug 2, 2009 | 03:04 PM
barneyb's Avatar
Forget the console, the backup light switch is on the transmission. If you have had clutch work it probably isn't plugged in.
Old Aug 3, 2009 | 02:40 AM
spiderseth's Avatar
Thanks Fellas gonna check it out today when I get out of work.
