help please
Old Aug 14, 2009 | 09:36 AM
owens9080's Avatar
help please
my evo has no cat and has upgraded turbo....my engine is running lean after a tune with too much air to fuel ratio....could that be because of the o2 sensor or is that a serious problem
Old Aug 14, 2009 | 09:44 AM
chaotichoax's Avatar
what are you basing your "my engine is running lean" comment off of?
who tuned the car?
when you say o2 sensor are you referring to a wideband or a stock o2 sensor?
Old Aug 14, 2009 | 10:39 AM
gsrboi80's Avatar
+1 as stated we need more info man
Is it running lean during cruise or WOT. Are you judging that by looking at your wideband gauge?
During cruise the car runs in closed loop meaning it uses the cars front O2 to determine A/F
During WOT the car is in open loop and will look to target your Fuel maps set values
Old Aug 14, 2009 | 11:37 AM
owens9080's Avatar
no like the car has a high idle and if i dnt keep it up the car stalls out on me and then i checked the codes and it said that the engine isnt getting enough fuel....is it because of the upgraded turbo...and also its a stock o2 sensor
Old Aug 14, 2009 | 12:44 PM
owens9080's Avatar
anyone else have input
Old Aug 14, 2009 | 01:42 PM
bring your car to someone that knows what they are doing
Old Aug 15, 2009 | 02:10 PM
owens9080's Avatar
yea im probably gonna go do that
