turbo timer problem
Old Aug 21, 2009 | 08:07 PM
adammartini's Avatar
Unhappy turbo timer problem
my evo borke down on my way to cali and at the random mitsu dealership i took it to reset my ecu but and now the turbo timer sometimes seems to be like a fraction of a second off droping the rev but kicking in just before the car dies. every once in a while it is too late and the car turns off and the timer keeps counting down like its on. any way i can fix this?
Old Aug 23, 2009 | 11:59 AM
anyone? anyone ever had this problem?
Old Aug 24, 2009 | 01:35 PM
lame.... i guess ile just pull it then put it back or try and take it apart and see if theres some loose wires or something inside of it
Old Aug 24, 2009 | 01:39 PM
MuslimEvoFreak's Avatar
Unplug the battery and see if it fixes the problem. If not then I would try un-plugging your harness you bought to install the TT with. Also, if you have the "kill-switch" of the TT connected to your e-brake, try disengaging the e-brake before the TT turns off and if it is still a fraction of a second off then maybe that might be your problem.
Old Aug 25, 2009 | 01:48 PM
WRECKLESS96's Avatar
there is a good chance that they ign and the acc wires off of the turbo timer are switched.
if its a greddy turbo timer the ign says on the entire time. but the acc wire only turns on when you turn the key off
Old Aug 25, 2009 | 06:55 PM
EVO8emUp's Avatar
Mine does this for a fraction of a sec., never stalls the car though.
