Anyone on here use Kroil?
Old Sep 11, 2009 | 09:19 PM
heavens turbo's Avatar
i use it at the refinery i work at. great on rusted *** pumps and turbines. still gotta use the torch sometimes though.....
Old Sep 12, 2009 | 05:31 AM
gunhaha's Avatar
The oil that creeps.
I didn't know they now comes in aerosol spray.
I buy the ones in cans at the gun show.
Old Sep 12, 2009 | 09:21 AM
raginghadron's Avatar
I'm sure most of you have seen this by now but here it is for posterity:
Code:
The April/May 2007 edition of Machinist's Workshop did a test of
penetrating oils where they measured the force required to loosen
rusty test devices. Buy the issue if you want to see how they did the
test. The results reported were interesting. The lower the number of
pounds the better. Mighty interesting results for simple acetone and
tranny fluid!
Penetrating oil		Average load	Price per fluid ounce
None			516 pounds
WD-40			238 pounds	$0.25
PB Blaster		214 pounds	$0.35
Liquid Wrench		127 pounds	$0.21
Kano Kroil		106 pounds	$0.75
ATF-Acetone mix		53 pounds	$0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio).
Considering the fact that acetone is a strong solvent and not paint-safe, Kroil does a pretty damn good job.
Old Sep 12, 2009 | 07:00 PM
red evo8's Avatar
looks good but pb blaster has never failed, so why replace it ? thats my 02
Old Sep 13, 2009 | 08:22 AM
Sounds like you've never had the luxury of owning a car that has rusted, seized bolts on it. PB is great for day-to-day removal of mildly old and stuck bolts but it's not the end-all of penetrating lubricants. I mean sometimes it just doesn't cut it no matter how much you hose down your parts with it. Anything that reduces or eliminates the chances of galling or even shearing a bolt even further is easily worth consideration.
Old Sep 13, 2009 | 09:55 AM
Skott2k's Avatar
Im about to be changing my exhaust out and i hear the bolts on it are rediculous, ill be getting a can of that, thanks for the info.
Old Sep 13, 2009 | 10:00 AM
Import Junky's Avatar
I work at the Sunoco Refinery in Philadelphia and this is all we use. I've never heard of Kroil until I got here. It's the best stuff I've ever used.
Old Sep 13, 2009 | 10:07 AM
denver's Avatar
At the machine shop I used to work at we would use it by the case! I definitely recommend it! Its better than anything else you can use. I used it one time on a 1951 front loader tractor that had been sitting in a field with the tracks buried ... I didnt break a single bolt!
Old Sep 13, 2009 | 10:11 AM
mmmmbst's Avatar
Veteran: Air Force
i agree. i use it at work and its never failed
Old Sep 13, 2009 | 12:06 PM
red evo8's Avatar
true, when pb blast fails me this will be next on my list.
Old Sep 13, 2009 | 12:43 PM
TS8's Avatar
TS8
Aerokroil is the best. I am an aircraft tech, and we use it on multimillion dollar parts.
Old Sep 13, 2009 | 01:31 PM
andymilonkis453's Avatar
Can anyone help me. I have a 2002 mitsubishi lancer OZ RALLY and Im still kinda a noob but i need to replace my downpipe but I cant seem to find an aftermarket one for my car. Does anyone know of any company that makes non evo downpipes for the oz rally?
Old Sep 13, 2009 | 01:40 PM
cruzzinlow's Avatar
+1 on the Kroil... i work for a underground gas utility company where every thing steel in the ground is badly corroded and Kroil is the only thing we use..
Old Sep 13, 2009 | 01:48 PM
cruzzinlow's Avatar
and as far as being paint safe, we have also used Kroil to remove grease and gunk from our backhoes and skid loaders and its never done any damage to the paint.. but that doesn't mean i would ever let it touch my car.. hah
Old Sep 13, 2009 | 02:08 PM
mmmmbst's Avatar
Veteran: Air Force
Yup thats where I use it too.
