Using Regular 87 octane fuel.
Old Nov 15, 2009 | 11:59 AM
coryl's Avatar
Originally Posted by btownsoccer22
I use vegetable oil in my car
I have a friend who does that (what a hassle that is to go behind restaurants and take used grease/strain it/store it, etc)...he does not have an EVO, and he smells like a Chip wagon making french frys...lol.
Old Nov 15, 2009 | 12:16 PM
coryl's Avatar
Originally Posted by alexisrc
Hi Guys.
I would like to know if it is possible to fill the evo's fuel tank with Regular 87 octane fuel.
Don't know about gas in P.R., as I've never been there...is it difficult to find 91 or higher?
Old Nov 15, 2009 | 01:01 PM
buchnerj's Avatar
If your driving it like the car should be driven you are going to knock and it will 1) pull timing and 2) drive like poop. Any reason on why you would want to do this? Most of the people on here mod their car, so you spend all the money on top dollar mods and getting peak performance out of the car and then you put **** gas in it and it drives like ***. Doesn't make sense to me...
Old Nov 15, 2009 | 01:24 PM
MR Turco's Avatar
There is no reason for the crap talk that is in this thread.
To the OP, this can and has been done. I believe there is a thread in ECUflash section about running on 87. The OP of that thread i believe could get 18psi tune out of 87, not bad imo. I have also considered doing it for a DD tune. Why not right?
That said, you cannot just fill up and turn down the boost. You would need a proper tune with proper timing and fueling to be safe.
Old Nov 15, 2009 | 02:02 PM
alexisrc's Avatar
Here we have the same fuel as in the States, 87, 91 and 93.
DD evo 8, mods: bigger inter.,ARC intake box, Evo 9 turbo, 3" exhoust pipe, decat.
Highway miles most of the time.
I'm looking for fuel economy not for top performance at this time.
Old Nov 15, 2009 | 09:44 PM
kyoo's Avatar
You can, like others have said you'll need a tune.. IMO its pointless, you don't save that much money, and there's always public transport if you need to save money
Old Nov 15, 2009 | 10:55 PM
coryl's Avatar
Who takes the bus when you have an EVO?
Does that car take 91 or 93 octane? My EVO X takes 93, but I can only get 94 around here...it's about $.20 more per liter than 87 octane.
Old Nov 16, 2009 | 08:46 AM
MR Turco's Avatar
I already asked people to cut out the crap talk. The OP has a legitimate question, which has been answered. No one cares if you agree or not. Stick to technical input or dont post.
Old Nov 16, 2009 | 09:22 AM
EvoRob22's Avatar
Hi Guys.
No. The engine is designed to take 91 Octane to reduce knock. Everything in the car is designed for 91, this includes the fuel pump, lines, filter, pressure regulator, and the engine internals. Use of 87 over an extended amount of time will do two things. It will create knock in the engine which is not a good thing at all, and two it will destroy your catalytic converter.
Old Nov 16, 2009 | 09:55 AM
alexisrc's Avatar
Thanks to all guys for your great and helpful opinions. I'll stick with the 91-93 octane fuel. To Aschold you have no need for use the hostile language. Thanks MR Turco. Rules are rules.
Old Nov 16, 2009 | 09:59 AM
4WS Tuning's Avatar
If youre tuned for 87... sure... Don't expect alot of power though...
I drove my car 2400 miles round trip on 87.. saved prob about $100-$120.. was worth it since i wasn't racing anyone...
Cheers!
Old Nov 16, 2009 | 10:08 AM
MR Turco's Avatar
How will it destroy your cat? Octane is essentially knock resistance, the more octane more knock resistance (http://en.wikipedia.org/wiki/Octane_rating). Octane should no affect anything else other than the ability to resist knock. Additives to fuel, lead, ethanol, are what need to be considered with other components.
Like i said. The car is designed to have fuel with higher knock resistance. Proper timing and fueling (read: retune) WILL allow the car to run a lower octane fuel.
Old Nov 16, 2009 | 10:28 AM
mifesto's Avatar
mr turco, you beat me to it.... evorob22 is pulling facts out his ****.... what does fuel filter and pump etc has to do with octane rating. i cracked up reading his response.
PEOPLE!!!!~ octane is for knock reduction and has nothing to do with anything else like "cleanness" or compatability of any hardware
Old Nov 16, 2009 | 10:34 AM
felickz's Avatar
Originally Posted by smarti
don't do it if your tuned
unless for some strange cost saving reason your tuned to run on it....
Old Nov 16, 2009 | 11:02 AM
laz1e's Avatar
not worth saving the dollar in my opinion... you can do it if u want though.
