Question on Tomei DV
Old Dec 15, 2009 | 03:49 PM
AJR-Coco's Avatar
When you purchase the Tomei DV does it come with the recirculating hose? and if it doesn't anyone know where i can get just the hose? is it normal length hose or can it be custom for a bit longer because some UICP its different.
Old Dec 16, 2009 | 02:39 PM
aschold's Avatar
I'm going to assume that it probably isn't included. Externally it's exactly the same as the IX MR metal DV.
Old Dec 16, 2009 | 04:25 PM
halfnhalf83's Avatar
^^ it does not come with the recirculating hose ^^ its also the same size as the IX MR metal DV. so u can use the OEM hose
Old Dec 16, 2009 | 04:35 PM
AJR-Coco's Avatar
sounds good anyone has the oem hose for sale!?
Old Dec 16, 2009 | 08:43 PM
aschold's Avatar
I have an OEM one that I can sell you.
Old Dec 16, 2009 | 08:46 PM
Evokid03's Avatar
^ Just go to a local parts store and find a radiator with the right bend you need.. Its a 1" diameter hose im pretty sure.
Just find a hose with a proper bend u need and length then cut / mod to fix.
Thats what i did all the time
