Fit ebay lip in evo 8??
Old Jan 5, 2010 | 04:34 AM
Oettinger's Avatar
This lips fits good in evo 8?? Is plug and play?? Thanks!
http://cgi.ebay.com/ebaymotors/03-05...Q5fAccessories
Old Jan 5, 2010 | 04:38 AM
tim85851's Avatar
i have this lip...its a direct bolt on...just take your oem lip off and bolt this one in place...
line the lip up...make sure you drill pilot holes and bolt the lip on from the middle first and work your way out on each side...
Old Jan 5, 2010 | 04:39 AM
tim85851's Avatar
https://www.evolutionm.net/forums/ev...green-evo.html
Old Jan 5, 2010 | 04:53 AM
Oettinger's Avatar
I need driller my bumper for install this lip? And other question, where is your seller, is for buy the same lip for my evo. Thanks!
Old Jan 5, 2010 | 05:16 AM
tim85851's Avatar
no...the stock bumper has holes at the bottom where the lip attaches...you will see it when you take your bumper off and remove the factory lip...
just unscrew your factory lip, line up the new lip to the holes and drill small holes in the new lip so its easier to screw the lip to the bumper...
Old Jan 5, 2010 | 05:18 AM
tim85851's Avatar
when you buy from one of those vendors on ebay make sure their seller rating is high...i only buy from sellers that have ratings of 98% or higher...
Old Jan 5, 2010 | 05:33 AM
Oettinger's Avatar
Ok, perfect! Is plug&play i don't need driller, ok ok, perfect. Where is the best of 3 lip this links of ebay?
Old Jan 5, 2010 | 05:35 AM
tim85851's Avatar
just pick the one you think will be the best...
like i said before look at the seller rating...HIGHER IS BETTER.
Old Jan 5, 2010 | 05:40 AM
Oettinger's Avatar
ok, thanks. This 3 lip, where is your lip look? Your look is beautiful style for me!
Old Jan 5, 2010 | 06:32 AM
DenverEvo's Avatar
I just put that same lip on my car the other day. Can't say it was the same seller because there are tons of people selling it all over Ebay. But I would say fitment was a 9 out of 10. One hole on the side of the lip didn't match up so I had to do some engineering......
Old Jan 5, 2010 | 07:58 AM
Audi2Evo's Avatar
whats this about having to take the bumper off to put this on? cant you just jack the car up??
Old Jan 5, 2010 | 08:10 AM
Oettinger's Avatar
Your engineering drilled the bumper is visible this hole when fit other day the stock lip?
Old Jan 5, 2010 | 08:17 AM
Aman's Avatar
i have same lip to, but bought it from a different seller after i broke my cf lip. fitment is not easy. drilling and sanding is required to make it fit properly. bumper must be taken out to make it fit properly.
Old Jan 5, 2010 | 08:29 AM
tim85851's Avatar
its not required...but if you want to do it right and not have a saggy lip then by all means jack it up and use jackstands...
Old Jan 5, 2010 | 01:33 PM
Oettinger's Avatar
Ok Ok, perfect, for better fit, one hole in the sides, ok, perfect!
