Help cant shift after transfer case fluid change.
Old Jan 11, 2010 | 07:17 PM
gallas's Avatar
Originally Posted by Evonrails
sounds like throw out bearing isn't attached anymore. How does the petal feel?
the pedal feels the same and if their is a difference, it is minimal.
Old Jan 11, 2010 | 07:20 PM
gallas's Avatar
Originally Posted by november
If it happened when you hit the snow should you either have a lot of fluid in your bay or at least in the snow from something getting disconnected?
I'm just trying to thing logically about it and you changed xfer and dif fluid, nothing to do with the trans.
Look under the car I guess, see what's different.....something obviously changed and there has to be residue/fluid somewhere.
i looked for fluid but didnt see anything that allready wasnt their (bad rear main seal...) but i traced the clutch line and looked at everything i think it could be and didnt see anything out of the ordinary, i am just getting off work and will drive down to take a look now that it has been sitting over night, and see if their are any puddles..
Old Jan 11, 2010 | 07:48 PM
millsyy17's Avatar
Veteran: Army
not sure dont quote me 100% but i know your suppose to have added fluid with LSD additive in it...its a MUST
Old Jan 11, 2010 | 08:09 PM
gallas's Avatar
yes it does have that in it
Old Jan 11, 2010 | 08:18 PM
5LEEPERISAH23I's Avatar
lsd additive in tran's or t-case?
Old Jan 11, 2010 | 09:39 PM
gallas's Avatar
Originally Posted by Duh Panda
pop the inspection hole at the bottom of the tranny.... look inside and see if the retainer clip is still in place.. if it is dont sweat it.. just start small
Ok i poped the inspection hole and took a peek inside and everything looks ok but then again i dont have much experience with clutches. can some one tell me how i can tell by looking at it if the retainer clip is in place. i have a service manual but its not doing me to much good...
Old Jan 12, 2010 | 01:14 AM
boostless's Avatar
A friend and i just changed our fluids and IT DOES matter. I used a different combination of Redline than he did. He now has to work the shifter around before he can go into gear when it is cold.
Old Jan 12, 2010 | 02:37 PM
gallas's Avatar
So are you saying that you think it could just be my fluids i used??
Old Jan 13, 2010 | 10:16 AM
gallas's Avatar
bump
