RPM drop...
Old Jan 19, 2010 | 02:43 PM
kenshi3's Avatar
RPM drop...
My RPM drops below 1 when I put it to neutral when say driving to 3k rpm on any gear and shifting it to neutral and my rev goes down to nearly 0 and the car shakes a bit like its about to stall. It stalled once couple days ago when I was still at 30km/hr . I got a injection fluid clean out of some sort from my local car shop and it still has the same problem. The car shop is working on my car right now to see whats the problem. He predicts its the throttle problem. I'm wondering if anyone has this type of problem before and how to solve this issue. I also changed my oil just last week, so shouldnt be that either.
Thanks for your guys help ~
Old Jan 19, 2010 | 03:41 PM
chaotichoax's Avatar
mods?
do you happen to have a vta bov?
any vacuum leaks?
Old Jan 19, 2010 | 04:30 PM
Murf's Avatar
^yes, mods? Do you have and aftermarket intake? That was my problem when my car was doing that. Tuned it out a few times but it would come back. Stock intake now no problems
Old Jan 19, 2010 | 07:28 PM
kenshi3's Avatar
I have Blitz BOV, AMS turboback and ARC induction box. Any of these would affect it? The guy said replacing the spark plugs and the spark plug wires would do but he said just the wiring is $100... i feel ripped off.
Old Jan 19, 2010 | 07:34 PM
kenshi3's Avatar
Thing is though I had no problems with the intake and exhaust for over 4 months now bov was put on 2 weeks or so but had no problems till say 5 days ago?
Old Jan 20, 2010 | 10:20 PM
kenshi3's Avatar
replaced spark plugs and the spark plug wires... no help
Old Jan 20, 2010 | 10:52 PM
blkVII's Avatar
I know aftermarket intakes (pipes) can cause the MAF to go a bit haywire.. Also believe a lot of Evo's have a problem with the TPS I think or maybe the idle control valve?
Mine does this as well (throttle hangs as well).. A fair few Evo's in Aus also have this same problem you're having.. Some people said faulty ICV I think, but also others said its an ECU related issue that's there to cheat emissions or something..
I'm sure there's people on here that have heard of this issue before and know a solution/what causes it..
Old Jan 20, 2010 | 10:59 PM
Kracka's Avatar
Is your Blitz BOV setup to VTA?
Old Jan 21, 2010 | 02:01 AM
kenshi3's Avatar
This is my bov :
http://www.advancespeedshop.com/blit...1-p-11966.html
Its for evo 8s... shouldn't be a problem it was a direct bolt on by my local car shop. Should there be any specifics I should tell him to prevent this problem?
I haven't tuned my car yet , but I don't want to drive down to WA with this problem occuring .
Any ideas? Thanks.
Old Jan 21, 2010 | 02:11 AM
tro0xazn's Avatar
most likely its your BOV...
your local shop just ate a lot of money from you,
oh well at least you got a lot of things replaced right? :/
try blowing off and then putting your car into neutral see if it affects it..
also notice whether your using your A/C or not...
Old Jan 21, 2010 | 03:04 AM
kenshi3's Avatar
yep...
mmm i do that and the rpm just drops below 1.... only when im revving it doesnt do that..
Old Jan 21, 2010 | 03:16 AM
smokedmustang's Avatar
start puting the stock stuff back one piece at a time. then when it stops, you found your problem. it IS the BOV if you want my vote.
Old Jan 21, 2010 | 05:32 PM
kenshi3's Avatar
I don't want to put the BOV to waste as it was a gift from my family member. Is there a way to solve this problem?
Old Jan 21, 2010 | 07:38 PM
blkVII's Avatar
Is it set up to recirc or VTA?
Old Jan 21, 2010 | 08:12 PM
kenshi3's Avatar
no idea, all I know is that the guys just replaced my old APS bov with the new blitz one. Which setting should I tell them to adjust or should I just wait till I go down to English Tuning and let them handle it for me?
