Car has been sitting...couple questions
Old Mar 21, 2010 | 05:50 PM
rayman0690's Avatar
Alright so my clutch turned to a nice pile of dust around December 9, 2009. It is now almost April 2010. It will be fixed in the next few weeks.
My question is this:
It has had (from what I remember) about 3/4 of a tank of 93 Premium in it for most of that 4 month sit time. It has been started a few times in between but due to some of the other repairs I have been doing it hasn't been started in about...say, 3 to 2.5 months?
Will that cause me problems?
Before it gets fully driveable it will end up having lots done to it. Including a clutch job, all fluids redone, including oil change and antifreeze flush and refill.
But I am mostly concerned about the fuel sitting. Is this ok? Do I have to empty it?
Old Mar 21, 2010 | 06:06 PM
Foolproof's Avatar
You can empty it or finish filling it up and just stay out of boost for a tank and it shouldnt hurt anything
Old Mar 21, 2010 | 06:08 PM
evo unknown's Avatar
Top the tank off with fresh gas and stay out of boost until empty. You won't really be able to get on it much with a new clutch anyway.
Old Mar 21, 2010 | 06:55 PM
ashills's Avatar
I would put a can of Seafoam in your tank.
Old Mar 21, 2010 | 09:06 PM
blaze9489's Avatar
3 months? i think youll be okay. drain it if you really dont want to risk it. easy enough
Old Mar 22, 2010 | 02:02 AM
Slayaaah's Avatar
It would run on it - no problem. But stay out of boost cause you might end up with knock otherwise. For storage - either have the tank completely filled up or even better - leave it with like 3 gallons and just go fill it up when you take it out.
Motorcycles, ATV's etc with carburators often gets a real headache when trying to start em up on old fuel.
Old Mar 22, 2010 | 02:20 AM
ChopShop's Avatar
My X sits for months at a time....(get to drive it every 6 month or so) Fires up and runs just fine. I do stay out of boost for about a day and a half.
Old Mar 22, 2010 | 06:21 PM
rayman0690's Avatar
Thanks everyone. I appreciate it!
Old Mar 22, 2010 | 07:54 PM
metal4all6's Avatar
You should be fine. Last time I filled my car up was in mid December and it still runs fine. I was just out driving it today and had no issues.
Old Mar 23, 2010 | 06:44 AM
HxllxMan's Avatar
I put my car in storage for a 1year ( Dec 09 ). And will probably start it again around January 2011. I mix the fuel with some kind of fuel treatment / storage to minimize water formation and corrosion in fuel system.
But I will drain it to be on the safe side.
Old Mar 23, 2010 | 07:37 AM
evremonde's Avatar
i believe that gasoline will 'sour' after 30+ days. Not sure of what happens, but it can cause problems for both carbs and injectors. That said, I would just drive it.
after a few months your only concerns will be fuel and battery. Drive gently for a while, not only to prevent knock, but also to make sure that the oil cycles thoroughly.
