TB Shaft Seals
Old Mar 22, 2010 | 03:28 AM
03nmeva's Avatar
TB Shaft Seals
Ok so i have a boost leak thats coming from my throttle body and my blow off valve and im gonna replace the shaft seals. So my question is which shaft seals should i use? The Mil.Spec ones or the Works ones? im not sure which ones to go with so let me kno
Old Mar 22, 2010 | 03:51 AM
Q8_EVO's Avatar
Mil Spec
Old Mar 22, 2010 | 04:57 AM
mrboost05's Avatar
ive used the mil spec and they worked well so far he has a vendor thread somewhere on here he ships fast and will even send a throttle body gasket if you want.
Old Mar 22, 2010 | 05:12 AM
Kracka's Avatar
Mil.Spec; get a new TB gasket too as mentioned above.
Old Mar 22, 2010 | 05:14 AM
Domolution's Avatar
Originally Posted by q8_evo
mil spec
+1
Old Mar 22, 2010 | 07:38 AM
FQ-300's Avatar
Mil Spec
Old Mar 22, 2010 | 08:05 AM
lemmysports2's Avatar
im sure there both basically the same.. i have the works, they went in easily and ive had no problems with them
Old Mar 22, 2010 | 08:09 AM
mifesto's Avatar
sorry if this is slightly off-topic but i'm sure i'm not the only one who wants to know.... the install walkthrough i believe said to lub the TB seals when you push them back in.... any recommendations on the lub?
Old Mar 22, 2010 | 08:10 AM
xtnct's Avatar
I put the Works ones in about 2 years ago.
Old Mar 22, 2010 | 08:12 AM
Foolproof's Avatar
Just ordered the Mil.Spec. Stockers are leaking bad
Old Mar 22, 2010 | 08:19 AM
MR Turco's Avatar
Mil.spec. I have installed dozens of these.
Old Mar 22, 2010 | 08:22 AM
BoostWhore's Avatar
Search theres a DIY on how to do it. As for lube just put some synthetic grease nothing special.
Old Mar 22, 2010 | 08:25 AM
i used a small amount of lithium grease on the outside of the seals to help them slide into place and on the tb shaft itself cause its a moving part
Old Mar 22, 2010 | 08:27 AM
MR Turco's Avatar
i use dielectric grease
Old Mar 22, 2010 | 08:50 AM
churbo's Avatar
I used dielectric grease as well. I went with the WORKS seals. I have one seal because i f'ed on of them up and had to buy another set. I got mine for 20 shipped.....I can hook you up if you pm me
