oem boost controller help
Old Apr 2, 2010 | 10:47 AM
smithrcing17's Avatar
Like the title says i need help with the oem boost controller, the guy who owned my car before me was running an apexi avc-r but im selling it because i need money to pay off my car and im just going to run the oem one until i can afford a cheap manual controller, i need to know which vacuum line goes to the turbo and which goes to the wastegate???
Right now i have the wastegate vacuum line hooked up on the left side and turbo vacuum like on the right side, is this correct? i dont want to start the car before i know if this is right or if it even matters which one its on..
Old Apr 2, 2010 | 10:55 AM
GST Motorsports's Avatar
You need a T inline. One side to the WGA, the other side to the compressor outlet pipe and that section has a restrictor pill in it.
The top port on the stock BCS vents and should go to the induction tube (with the MAF on the end)
Take a look at the T in this image (ignore the solenoid side section as it's for the evo 10)
- Bryan
Old Apr 2, 2010 | 10:57 AM
IrightI's Avatar
Make sure you use the stock lines with the pill in them.
look at the last post..
there are some images.
https://www.evolutionm.net/forums/ev...quesetion.html
Old Apr 2, 2010 | 11:04 AM
so i have to use the stock lines with that pill in it?
Old Apr 22, 2010 | 10:29 PM
domantas's Avatar
im in same situation... have no stock vaccum hoses, not tee or pill... Do I need to purchase from Mitsu all of this or just line to gate, pill and tee should do it?
Old Apr 23, 2010 | 01:18 PM
EvoJoeIX's Avatar
no. just get any vacumm line, run one from wastegate to right nipple on boost controller, then run another line from turbo nipple to other nipple
_Ryan_
May 16, 2015 10:01 AM
Spoolin4g63
Aug 23, 2011 09:54 AM
grey03cobra
Nov 17, 2007 06:50 PM
AutoEuphoria
Jun 21, 2006 09:24 PM
bishiboy
Apr 18, 2004 02:32 PM
