help!dont want my engine blow
Old Apr 8, 2010 | 10:03 PM
kanyonkid's Avatar
take a gander at ur spark plugs since the information were getting isnt good enough
Old Apr 8, 2010 | 10:04 PM
evo unknown's Avatar
How many miles are on the car? What maintenance has been done? Spark plugs changed?
Old Apr 8, 2010 | 10:08 PM
subliminal's Avatar
no gauge to monitor the boost... and i dont get full power
Old Apr 8, 2010 | 10:13 PM
subliminal's Avatar
spark plugs have been changed about 1000 miles ago the car has 44 thousand miles the last oile change was done about 30 miles ago i used full synthetic royal purple with a knn oil filter spark plugs r ngk laser iridiums.
Old Apr 8, 2010 | 10:15 PM
kanyonkid's Avatar
im going with the spark plugs then... my car doesnt like "special" plugs...
Old Apr 8, 2010 | 10:18 PM
AznEvoIX's Avatar
First upgrade on Evos should always be a boost gauge. That little thing can tell you many things.
Old Apr 8, 2010 | 10:20 PM
subliminal's Avatar
this is the third time i use the lasers never had a problem
Old Apr 8, 2010 | 10:22 PM
kanyonkid's Avatar
its funny how things work that way.. I had my plugs gapped at .026 for 2 years, now she wont run unless they're at .022
Old Apr 8, 2010 | 10:27 PM
subliminal's Avatar
things do change ima go check that out
Old Apr 8, 2010 | 10:28 PM
subliminal's Avatar
so wat might of caused the light to come on and giving me a code p0236(overboost)
Old Apr 8, 2010 | 10:32 PM
kanyonkid's Avatar
not sure, u need to do a few things to narrow it down... i tried a set of iridium plugs one time and my car acted crazy, i had 3 codes pop up but i knew they were from the plugs and just erased the codes..
Old Apr 8, 2010 | 10:37 PM
subliminal's Avatar
i tried to narrow it down but i keep on coming up with the same thing rather the air filter or the maf sen
Old Apr 9, 2010 | 03:03 AM
FoxFister's Avatar
That sounds ALOT like plugs to me. From what your trying to say is that the car is bucking when you go WOT?
When I changed my plugs I tried those ****ty *** iridium plugs since that was what was in the car when I picked it up. Was doing the same thing your explaining so I picked up a set of BPR7ES's, problem solved.
Old Apr 9, 2010 | 04:48 AM
jmelocik's Avatar
Ok you got an overboost code, you heard a little explosion, and your car doesn't hit boost now? I would bet my next mod on you blew a coupler or IC pipe OR you blew one of the lines that goes to any of the many other items that need boost/vacuum reference. Do a boost leak test. if you don't have a boost leak tester, PM me and I'll send you one. Search on here for how to do a proper boost leak test from the turbo inlet, not the charge pipes.
Josh
Old Apr 9, 2010 | 05:42 AM
delongedoug's Avatar
I agree. It sounds like a boost related pipe issue to me.
