Do I need to be retuned?
Old Apr 22, 2010 | 09:22 AM
m4tt VIII's Avatar
Hi Everyone,
I am about to get my VIII back from the shop and I was wondering if I needed to be retuned. I had my stock block pulled in favor of a built 2.0L
Built 2.0L Specs
AMS Pistons
Pewter Rods - Std. Height
Knifedged Crank
ARP Hardware Throughout the Complete Engine
ACL Trimetal Main/Rod Bearings
Balance Shaft Eliminated
New Water Pump
New Oil Pan
New Oil Pump
I needed to get a new set of Head Studs and instead of getting another pair of ARP's, I decided to go with the MAPerformance Studs with the Dog Point Feature...
MAPerformance Releases 8740 Chromoly 4g63 Head Studs with Dog Point Feature!
The car was originally tuned for:
GSC 274 Intake Cam Ver. 2
GSC 272 Exhaust Cam Ver. 2
I need to replace the Exhaust Cam and I am just planning on switching to Kelford 272's (Supertech Springs, Ti Retainers)
For the time being I am planning on swapping in my stock cams...
The car is getting a new OEM timing belt and OEM head gasket.
I am swapping out my single disc clutch for an Exedy Twin HD (SS Clutch Line and STM Clutch Fork)
Mod list from before and after the short block swap:
BoostLogic SC61 DBB Turbo Kit
HKS DLI 2
AMS Front Mount Intercooler
Vishnu Signature Turbo Back Exhaust w/ Test Pipe
Mitsubishi JDM IX MR BOV
Walbro 255 Fuel Pump
Turbo XS Upper Intercooler Pipe
SMC Meth Kit Ver. 2
Precision 880cc Injectors
(GSC 274 Intake Cam Ver. 2 ---- Planning on putting in stock cams
GSC 272 Exhaust Cam Ver. 2) --- until the car is tuned
The car is currently tuned on 93oct + Meth Injection. I would like to be able to normally run the car on just pump and have a second tune down the road for pump + meth.
Basically, I am just wondering if I need to get the car retuned before I drive it or if I can drive it. I plan to have the car tuned down the road, but I am getting near the end of the school year and then I am studying abroad in Europe so I just don't have much time right now.
Thanks in advance,
Matt
__________________
Old Apr 22, 2010 | 10:02 AM
chaotichoax's Avatar
could you drive it? probably
I certainly wouldn't try and boost it or push the car at all without a retune
if you honestly are considering driving it without a tune then you need to rethink things
why rebuild the motor and then drive it on a tune for a completely different motor...that's asking for trouble
Old Apr 22, 2010 | 10:44 AM
m4tt VIII's Avatar
I want to have kelfords and a tune done at buschur (4hrs from me). I need to break the clutch in and I don't plan on boosting at all. I do not want to do anything harmful to the car, this is why I'm asking.
Old Apr 22, 2010 | 10:49 AM
4WS Tuning's Avatar
If you're looking for a base map to hold you over shoot me a PM and i'll set something up for you.
Cheers!
Old Apr 22, 2010 | 12:59 PM
evokid511's Avatar
4ws ftmfw!
Old Apr 22, 2010 | 02:51 PM
m4tt VIII's Avatar
Cheers!
Thanks! I look forward to working something out. As of now the plan is to have the car flashed by 4WS until I get her dyno tuned.
