Check engine light?
Old May 12, 2010 | 09:04 AM
bbyevo8u's Avatar
Check engine light?
I just got a check engine light, can I just go to autozone and get it checked?? Sux I'm getting fp red and some other mods with a tune this weekend I'm hoping this isn't going to hold me back now been waiting so long to get my mods installed and now this hope it's just a sensor or something.
So what the best way to get it checked out without costing much? Thanks
Old May 12, 2010 | 09:05 AM
erald01's Avatar
autozone will pull the code for you , BUT i can guarantee its either bad o2 sensor or missfire...let us know
Old May 12, 2010 | 09:06 AM
evo8fl's Avatar
just go to autozone is free
Old May 12, 2010 | 09:08 AM
RockmanX's Avatar
this is probaly correct
Old May 12, 2010 | 09:35 AM
Blowstock06's Avatar
Ditto
Old May 12, 2010 | 09:49 AM
FooM Anchoo's Avatar
hope its not a bad 02... damn thing is almost as high as the FP RED!!!
Old May 12, 2010 | 10:00 AM
bbyevo8u's Avatar
What are you talking about?
Thanks guys! I'm getting it checked today
Old May 12, 2010 | 11:22 AM
bbyevo8u's Avatar
How expensive is the 02 sensor and how do you replace it cut and splice or is there a harness??
Old May 12, 2010 | 11:26 AM
turbotalawd's Avatar
The front O2 sensor is cheaper than the rear. The front should be somewhere around $60. You can get one with a harness thats just plug and play or you can get one for a little cheaper that your gona have to splice wires into your existing O2 harness.
Old May 12, 2010 | 11:40 AM
bbyevo8u's Avatar
Ok thanks!!
Where is the front one? I have my a/f sensor in my 02 housing and I don't remember putting one in the downpipe!?
Old May 12, 2010 | 11:43 AM
erald01's Avatar
front one is on the hot side housing of the turbo, the housing that connects to the downpipe.
Old May 12, 2010 | 12:34 PM
bbyevo8u's Avatar
The downpipe bolts to the 02 housing
Old May 12, 2010 | 12:37 PM
Genesis8's Avatar
Just get a Universal 02 from Autozone which is cheaper then buying one from the dealer if your 02 is bad.
Old May 12, 2010 | 12:39 PM
EvoFredo's Avatar
did i miss it ? what was the code. autozone will check it for you for free. or if you dont care pull the engine fuse to reset the ecu.
Old May 12, 2010 | 04:22 PM
erald01's Avatar
your wideband sensor should NOT be at your o2 housing, it should be by your downpipe usually where the second o2 sensor sits
