Worse performance with new spark plugs?
Old Jun 15, 2010 | 09:10 PM
TrEvoRS's Avatar
After 50k miles I thought it was time to change my spark plugs before last weeks redline TA event. It is a stock Evo 8 except for a stock-boost mellon tune. I used OEM spark plugs, therfore did not gap (but checked and they were at the .021-.022 range).
The car feels noticably weaker, especially mid-range where the nice surge of torque seems significantly diminished. I checked the old plugs that came on the car and the gaps are .026 to .028. I think that is due to the erosion of the tips over 50k miles. Should I gap the new plugs to .026? I plan to experiment but if anyone has a similar experience I would appreciate the feedback.
Thanks!
Old Jun 15, 2010 | 09:17 PM
goldenEvo's Avatar
Changed my plugs with OEM plugs, I didn't feel any different.
Old Jun 16, 2010 | 12:17 PM
Mellon Racing's Avatar
I've not seen any hp difference due to plug gap...Ive run them down to .018 and made 700+awhp
I would do a boost leak test first and go from there.
Old Jun 16, 2010 | 11:16 PM
jonny2735's Avatar
I agree boost leak down test ftw
Old Jun 17, 2010 | 08:12 AM
DarksideZ's Avatar
Agreed, 1st thing I would check as well.
Old Jun 17, 2010 | 08:20 AM
05evoGSR's Avatar
my father used to have a machine that tested plugs under cylinder pressures and you would be surprised at home many plugs out of the box did not fire under full cylinder pressure. He went through about 20 new plugs before he found 8 that were still firing at the cylinder pressure range on his vette.
put the original ones back in, if it fixes the problem you know you have a problem with the new plugs.
Old Jun 17, 2010 | 08:24 AM
leonevox's Avatar
if u gap the plugs way off the recommendation range, your car or any car will run different my friend. I agree with u on doing a boost leak thou. Or something else wrong with his car.
Done
210
Apr 4, 2015 10:47 PM
kouzman
20
Jul 13, 2008 08:02 AM
Oracle1
Mar 30, 2008 09:57 PM
tripperfx3
Oct 27, 2007 04:40 PM
AlwaysinBoost
Aug 23, 2006 03:41 PM
