tial sounds like a turkey
Old Jun 24, 2010 | 01:56 PM
Darkn3s's Avatar
is it normal for my tial bov to sound like a turkey suddenly?? just thought it was kind of weird someone told me it might be surge?
running fp red with aquamist btw
Old Jun 24, 2010 | 02:43 PM
TJPhillips36's Avatar
What spring are you running? And when does it sound like this? Full throttle, half throttle, partial throttle?
Old Jun 24, 2010 | 02:52 PM
white_evo27's Avatar
mine sounds like that when i let off partial throttle... not sure if thats good or not, i havent gotten tuned with the BOV running VTA since im still on the stock MAF... switiching to speed density next week
Old Jun 25, 2010 | 07:00 AM
Darkn3s's Avatar
all the above and not sure the spring took it apart cleaned and greased it back up, spring isnt that stiff though
yea im still on stock maf. dont know anyone that can tune me on sd.. wish i could switch tho.. do u think not being tuned on vta causes this? anyone if its bad
Old Jun 25, 2010 | 07:09 AM
vanilla2's Avatar
Try recirculating it im sure your maf isn't too happy whit the vta
Old Jun 25, 2010 | 07:13 AM
Can't re-circulate it unless it's new Tial. May need a different spring though. What color was it?
Old Jun 25, 2010 | 07:14 AM
shh!! sleeping's Avatar
That sounds like Flutter to me... Partial throttle and minor boost in the engine and when you release the gas it goes ... Woop wooop wooop wooop... right?
That is just flutter... Pretty normal thing
Old Jun 25, 2010 | 07:15 AM
4g63smokinall4s's Avatar
really........ y post up when u dont know what ur talking about?
you cant recirc a tial 50mm or q.. unless its the new recirc version which im sure its not if he VTA..
check for any leaks.. maybe a pinhole in the line or somthing.. for it to do it randomly and out of nowhere somthing had to change to cause it.. check your lines.
what color paint does the spring have on it.
also what do you vaccum at idle?
or how much boost are u running?
the flutter is pretty normal on tials tho
Old Jun 28, 2010 | 09:12 AM
Darkn3s's Avatar
nope!
the spring was black, where can i get a replacement at?
hahah yea woop woop woop.. sounds pretty good imo but ppl tell me its not good
spring is black
just did boost leak test found 1 at the water meth bung.. fixed!
vaccum is like 15 i believe
boost is 24lbs
its just weird because it had the woosh sound at first then randomly changed to woop woop wooooooop
Old Jun 28, 2010 | 09:14 AM
Darkn3s's Avatar
also another weird thing i noticed is that when i pull the boost line from the bov it pops loud from all the pressure being held in.. not sure what that means
took it apart greased it up, checked the diaphram for any tears, leaks.. nothing bad. the BLACK spring looked to be in good condition as well
Old Jun 28, 2010 | 10:54 AM
THEevo8urV8's Avatar
i would get on that asap, when i had my old wrx i didnt tune it when i got my bov and it caused problems down the road.
Old Jun 28, 2010 | 10:45 PM
Darkn3s's Avatar
im tryn to
Old Jun 28, 2010 | 10:55 PM
Drew_FL's Avatar
Do you see a turkey call anywhere? :P im JK, everything sounds normal.
Old Jun 29, 2010 | 05:41 AM
Darkn3s's Avatar
oh
