my solution to those nasty front underbody panel trim screws.
Old Jul 20, 2010 | 07:33 PM
TommiM's Avatar
For anyone who has attempted to remove the lower body panel and gotten frustrated with those retarded clips, I made a solution.
I will try and get pics posted up soon of what the clips look like, along with part numbers and all that if anyone wants to do this as well. Basically I am replacing all those clips with screws and speed clips. A simple 8mm socket, and in much less time, its off. Its a relatively simple mod to do, The only plastic trim screw that I may have to resuse is the ones on the lower subframe, but those shouldnt really give you any issues since the panel screws there are mounted on a hard surface. I thought to post this up here since I hadnt really found anything on the how-tos.
Old Jul 20, 2010 | 07:37 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Let's see some pics. I hate those clips and seem to have lost about half mine.
Old Jul 20, 2010 | 07:39 PM
xmaciek82x's Avatar
My solution was a Beatrush underpanel
Old Jul 21, 2010 | 07:08 AM
evo8426's Avatar
mine too
Old Jul 21, 2010 | 07:12 AM
rsboy's Avatar
My solution is to hang the undertray in my basement.
Old Jul 21, 2010 | 07:13 AM
Standing Z's Avatar
+1 hahah
At least until I get an APR splitter
Old Jul 21, 2010 | 07:19 AM
rcheung's Avatar
+1
and those come with speed clips already.
Old Jul 21, 2010 | 07:27 AM
Blitz's Avatar
Originally Posted by rcheung
+1
Not really. A lot of guys (myself included) run the Beatrush with DZUS quick-release fasteners. If you install it with the included hardware, it will take forever to remove if you ever need to.
Old Jul 21, 2010 | 07:35 AM
evo8426's Avatar
well if i have to take the undertray off i usually just take the front bumper off. but that has happened twice, once to change the licp and the next time was to put the licp on again after it blew off.
Old Jul 21, 2010 | 07:37 AM
manni_t5488's Avatar
lol ^ :O)
Old Jul 21, 2010 | 12:14 PM
rcheung's Avatar
I changed out the hex bolts on the speed clips on mine and switched out for regular bolts with a 10mm 6 point head. With an air ratchet it goes in and out pretty quickly.
Old Jul 21, 2010 | 12:16 PM
gsrboi80's Avatar
LOL mine went right in the dumpster
Old Jul 21, 2010 | 12:27 PM
Lowso's Avatar
haha this keeps happening to me ive taken the bumper off 3 times.
Old Jul 21, 2010 | 02:16 PM
travman's Avatar
I use dzus fasteners w/ oem under-tray....so much nicer now.
Old Jul 21, 2010 | 06:45 PM
TommiM's Avatar
Here are some pics. I didnt put the undertray back on due to other projects I have going on.
these are the two main clips I ended up using. They are M10 speed nuts that I found at Kragen for 2.25 for a pack of 6, iirc. The bolts I ended up using were M4 1.41x20mm body bolts, part number 464200 from Kragen.
You can see where all the speed clips were installed on the ic tabs. I used the larger ones for these.
I installed the smaller clips on the fenderwell panels that you see here. The smaller ones fit better here, but for most everywhere else under the car you will need the larger ones. That clip is only partially installed so you can see it better.
Total cost for everything was about $15, so not too bad considering oem clips are pricey. Plus I feel this setup is more sturdy and easier to work on.
