Fuel Pressure to High!?!?
Old Aug 13, 2010 | 01:52 PM
OneCrzyEvo21's Avatar
Hey guys,
Installed the fullblown double pumper and I am running both pumps at the same time..I didn't drill out the stock siphon tube so i new that my fuel pressure at idle would go up.
It didnt really go up that much as i expected but it went up about 6psi over before to about 49-50psi..Called fullblown and they informed me that it is fine as long as you tune for it,
Would appreciate input thanks
Old Aug 13, 2010 | 04:55 PM
SDevo13's Avatar
They are correct. People run MUCH higher fuel pressures in some applications- all about accounting for it in the tune.
Old Aug 13, 2010 | 05:31 PM
Thank you sir! Appreciate the input, I can tell its running a lil rich but better than lean..Like you said ill make sure to account for it in the tune..
