Rear end removal?
Old Aug 15, 2010 | 12:00 PM
meckert's Avatar
Rear end removal?
Here is the issue--need to pull the rear end on and '04 VIII. Question is do I need to pop the suspension joints at the hub to pull the axles or is there room enough to swing the hubs out of the way and pull the axles after you remove the axle nuts. I figure something need to be taken off--- but which part so the hub has enough movement to pull the axle thru and swing out of the way so the axle can be take out--then unbolt the rear end and drop it down..
So who has done this and what the quickest way?
