Evo 8 Tire Question...
Old Aug 27, 2010 | 07:59 AM
krazybtch's Avatar
Hello! I just bought my first 05 Evo 8 RS. and had a question about tire size if anyone can help...
Has anyone ever used 215/55/17 on Evo 8s? Im still in the learning process with these cars because my husband has an eagle talon so I'm used to those and not 100% on the evos! Any help/advice for a newbie would be greatly appreciated!!!
Old Aug 27, 2010 | 08:06 AM
grillpt's Avatar
Common tire sizes for these cars are as follows... You can use these sizes for the stock wheels, although 255's do like a wider wheel, they will fit and be OK on a stock 8" wide wheel.
235/45/17 OE
245/40/17
245/45/17
255/40/17
I do not suggest going to a narrower and taller tire for everyday use.
Love your screen name btw!
Old Aug 27, 2010 | 08:10 AM
rovanpera's Avatar
unless you are buying a snow/ice studded tire.
Old Aug 27, 2010 | 08:12 AM
Genesis8's Avatar
+1 for snow tires.
Old Aug 27, 2010 | 08:26 AM
krazybtch's Avatar
235/45/17 OE
245/40/17
245/45/17
255/40/17
HAHA thanks! :]
It is my DD so they will be used for everyday use and as far as snow and ice goes, im in KY so one day it could be snowing and the next be 80 degrees outside so theres no telling what the weather will be like. I want to make sure the tires will fit ok and according to the standard sizes it appears it will just may be a little rough on her (yes my car is a her :])
Old Aug 27, 2010 | 08:27 AM
grillpt's Avatar
215/55/17 would be almost an inch taller than the same tire in the OE size 235/45. That would also have an effect on your speedo reading I would think.
Old Aug 27, 2010 | 03:31 PM
FQ-300's Avatar
If this is your daily driver, just stick with the OEM size, that way there is no confusion. There are many options in the 235/45/17 size that will fit your needs. Many reviews on TireRack to help narrow down your decision. Good luck.
Welcome2GoodBur
May 6, 2016 12:44 PM
trevor
Pacific Northwest
19
Dec 1, 2012 01:08 PM
SpeedI2acerX
Sep 26, 2008 12:25 PM
jhonard's_evo
Nov 6, 2006 01:32 PM
arnold16890
19
Jun 14, 2005 07:25 PM
