Any idea how to fix this?
Old Sep 25, 2010 | 04:56 PM
Dube's Avatar
I need a quick fix for this.. Anyone have any suggestions?
Whenever I try to loosen it, the nut loosens with it.. I tried hitting it with a wrench and even using pliers to try and hold it.. Can't grip it enough to loosen it.
Old Sep 25, 2010 | 04:58 PM
Evo1001's Avatar
buy another one from any auto-parts store
Dube's Avatar
Would I need to solder it?..
FedEvo8's Avatar
You can purchase a new battery terminal post connector at your local auto parts store. Just strip the wire and you can bolt the wire in place.
Old Sep 25, 2010 | 05:00 PM
ak47po's Avatar
Did you try vice grips?
Old Sep 25, 2010 | 05:02 PM
Dube's Avatar
Yeep. It's not enough to hold it. Pisses me off lol.
Old Sep 25, 2010 | 05:05 PM
ak47po's Avatar
It's just a ground wire get one of these at your local parts store.
Old Sep 25, 2010 | 05:15 PM
EVO8STI's Avatar
throw that thing away and buy a new one for like 3 bucks
Old Sep 25, 2010 | 05:38 PM
Dube's Avatar
Thanks everyone! Going to get it tomorrow. Hopefully everything will get fixed nowww.
Old Sep 25, 2010 | 06:29 PM
The-Evo's Avatar
+1. I concur.
Old Sep 25, 2010 | 06:53 PM
.50 Cal Cow's Avatar
You can buy lead caps for the battery terminals that will help secure it at any advance, pep boys etc.
Old Sep 25, 2010 | 07:06 PM
403evo's Avatar
as stated, not worth the hassle fixing, just replace.
but for something like that in the future on a more expensive part, get a blow torch on that nut.
heat = expansion = nut letting go of bolt.
Old Sep 25, 2010 | 07:36 PM
EvolutionVIIIrs's Avatar
please as stated replace that. Its worth the $5! Also, you should look into craftsman bolt out kits. Its a 13 piece set, and its made to get rounded bolt and such out. Works everytime!!!
Old Sep 25, 2010 | 07:58 PM
apexisilver8gsr's Avatar
just replace it man its like 5 dollars for both brand new ones
Old Sep 25, 2010 | 08:04 PM
SubieEvoGuy's Avatar
But for something like that in the future on a more expensive part, get a blow torch on that nut.
Heat = expansion = nut letting go of bolt.
+1
