Buying a "clean" Evolution 9?
Old Sep 29, 2010 | 11:06 AM
sblvro's Avatar
Some guidelines in buying a "clean" evolution 9! Comments here in this thread
https://www.evolutionm.net/forums/ev...gsr-se-mr.html
Old Sep 29, 2010 | 11:08 AM
Smike's Avatar
Originally Posted by sblvro
This thread is started in order for evolution enthusiasts to buy the perfect evolution 9 for their needs. Also, for potential buyers trying to find a low mileage, stock evolution 9.
1. Check for VIN numbers: make sure it matches all the body panels. areas to look for VIN: bumper-front and rear, front fenders, trunk lid, front and rear doors as well as the engine and tranny VIN are etched to these mechanical parts.
2. Low miles is the key. below 15K for an 06 would demand the highest bidder. 30-45k miles would be the usual mileage for a "low miles to year."
3. clean brembo's with no warped rotors. oem brembo pads means the owner wants oem materials.
4. clean interiors, if the vehicle as the original production stickers the better. the sunvisors have inspection stickers to it(!). The airbag sticker in the glovebox door if intact means the owners's intent in keeping the evo's value.
5. oem radio is actually a plus, since aftermarket install can mess up the wiring or can be mutiple taps on the wiring.
6. premium turbo timers and alarm combo means that the car was valued enough that a professional install of these was made. preferably: compustar and DEI products only.
7. oem wheels whether it was the BBS or the regular Enkeis in good to excellent condition is preferred coupled with Yokohama Advans A046 only. any other tire means that the owner took a cheaper route. Hankook, Bridgestone, Pirelli, etc. a no, no.
8. Regular maintenance schedule done by the dealer(only). A printout can be requested from the dealer by the owner or the buyer.
9. the usual carfax to determine if the vehicle was in an accident or not which can usually be determined if the VIN number sticker is missing. the usual loophole is using a CF hood, aftermarket bumper, CF trunk and aftermarket bumper to hide an accident. if the oem parts are available, then it is okay.
10. Preferably 1st owner vehicle. They can confirm the status of the clutch, repair work and maintenance, as well as the owner's manual, manufacturer/dealer sticker, etc.
Stuck thread! Great job!
Old Sep 29, 2010 | 11:32 AM
sblvro's Avatar
just things that I want to look for when buying the perfect stock evo 9
Old Sep 29, 2010 | 11:53 AM
FJF's Avatar
FJF
A couple of points, if I may:
Re: #6 - a turbo timer tells me the car was owned by someone who did not understand its mechanics
Re: #7 - expecting folks to buy OEM tires isn't very logical when newer, better compounds exist and/or when the owner's usage parameters require an alternate approach
Old Sep 29, 2010 | 12:07 PM
njboy's Avatar
I agree with FJF's comments. A turbo timer is not necessary since the turbo is oil and water cooled and the use of modern synthetics pretty much eliminates the chance of coking.
I would not consider Bridgestone a step down. They make excellent tires.
I would also like to add that one will be very lucky to find dealer only mantenance records. In fact I don't trust any dealer and would submit that my IX is better mantained by doing it myself.
Old Sep 29, 2010 | 12:10 PM
sblvro's Avatar
#6 was stated as a turbo timer/alarm combo which is sold by compustar. it is not about the mechanics of having an add-on turbo timer just because of the turbo nature of the beast. your statement then is wrong based on the wrong premise.
#7 better compounds for what? track days? autox? besides, if you have after market tires at 15k miles means it was driven hard. again, ^statement based on the wrong premise.
Old Sep 29, 2010 | 12:14 PM
sblvro's Avatar
Originally Posted by njboy
A turbo timer is not necessary since the turbo is oil and water cooled and the use of modern synthetics pretty much eliminates the chance of coking. .....
now, what happened to the alarm in the statement? it was meant as turbotimer/alarm combo which comes in the premium compustar model as well as DEI. It wasn't stated as a stand alone turbo timer.
Old Sep 29, 2010 | 12:17 PM
metalsaber's Avatar
RECEIPTS RECEIPTS RECEIPTS.
I keep all my receipts for all my purchases that go toward the vehicle. I suppose that would go towards documentation. Even if you did all the work yourself, I want to see what was purchased.
Old Sep 29, 2010 | 12:19 PM
FJF's Avatar
FJF
Why mention a turbo timer at all? Other features come with alarms, as well, but we're discussing a buyer's guide that should be relevant to the specific platform.
My point, exactly. OEM tires aren't necessarily applicable to many user-driven scenarios.
Or perhaps the owner living in, say, the NW wanted better wet-weather performance. Really, I think these two points should be modified.
Old Sep 29, 2010 | 12:22 PM
sblvro's Avatar
they(third party) should trust you more than the dealer? btw, bridgestone makes excellent tires but if you want to be a purist "stock" evo then the A046 is it.
Old Sep 29, 2010 | 12:36 PM
sblvro's Avatar
the premium-most expensive compustar platform comes with a turbotimer standard that is why it was mentioned. btw a lojack would also be a plus
true but that is what came with the vehicle oem advan A046. would you buy a used range rover with hankook tires. normally it comes with pirelli and the new ones come with michelin tires nowadays.
a second set of wheel and tires combo is even better
edit.
Old Sep 29, 2010 | 01:24 PM
FJF's Avatar
FJF
I run Hankooks on my own Evo and would not hesitate buying a car shod with an appropriate tire. I think it's clear that I'm not comfortable with some of the content and I will not be referring folks to the thread.
Old Sep 29, 2010 | 01:30 PM
Noize's Avatar
EvoM Administrator
I'm gonna side with FJF on tires. I drive my car 6/10ths at best, and get no life out of the Advans.
The only pro-case I can think of for the Advans would be if the car was so low on mileage in four years that the stock tires would not have worn out.
That would be such an IX I'd love to own! Unfortunately, it would also probably cost $26k+ easily.
Variety of opinions make the world go around. Let's all remember that.
Old Sep 29, 2010 | 01:34 PM
Smike's Avatar
How about we reword it a little. Something along the lines of which tire the car has tells a lot about its owner. Good tires Z1*, RE11, Hankook Evo, etc over Nexen, general (word not brand) all-seasons or other lower end brands.
The price of the A046s are absurdly expensive for a track/AX tire. Which is what they are. A sticky cheater tire to give the best handling at the expense of lower tread life. There are other, new tires and compounds that do that.
CAD EVO's Avatar
The list has some good points, no need to over analyze it.
You would be surprised what people overlook when they want a car.
