doing some service on my evo 9 soon
Old Nov 14, 2010 | 07:23 AM
impact blue's Avatar
Hey everyone I have a couple of questions
1- What kind of coolant do I use?
2- What kind of gear oil for the rear diff?
3- tranny oil?
Old Nov 14, 2010 | 07:32 AM
Hi Im Vinh's Avatar
I was once asking these questions myself when I started , searching is your best friend .
1. Oem is fine
2. Oem Diaqueen
3. If you have a MR 6spd. many say to stick with OEM, 5spd. either oem or amsoil.( I use amsoil)
Old Nov 14, 2010 | 10:44 AM
bigben's Avatar
Oem fluids are fine, but if you're not a fan of your wallet getting raped, here are some alternatives:
1: Prestone 50/50, 2 gallons (you won't use all of the 2nd gallon though)
2: Amsoil SVG, 2 quarts (1 for the tcase, 1 for the rear diff)
3: Amsoil MTG, 3 quarts
Old Nov 14, 2010 | 11:23 AM
EvoJoeIX's Avatar
i use amsoil in my 6 speed. works perfect and id recommend amsoil in everything except the transfer case and rear diff. i just stick to the oem fluids for them since they use the same fluid anyway. i wouldnt use any other fluid in the transfer case except oem.
Old Nov 14, 2010 | 11:40 AM
JohnDoe1984's Avatar
Make sure you get GL4 spec amsoil for the tranny. It doesn't shift right with anything except GL4. The tcase and rear diff get the same severe gear GL5.
