engine harness problem .... need help !
Old Nov 26, 2010 | 06:29 AM
master R's Avatar
basically ..... my ground near the water pump start to melt down and burn when a put the heat with light or a/c ...... so if i decide to put 2 or 3 things, (in same time ) in car ....the wire start to heat a lot and burn my engine harness ....the wire end near the top of the engine......
i was thinking about to change the complete electric harness or what ....
Old Nov 26, 2010 | 07:09 AM
Bobster22388's Avatar
Take your car to a shop and have it checked out. You may want to change the engine harness, but it's not an easy task and should be your last resort in this case.
Old Nov 26, 2010 | 03:27 PM
k3vmaster's Avatar
make sure theres no corrosion heat means theres resistence......
Old Nov 27, 2010 | 09:46 AM
master R's Avatar
problem solved ........one ground was loose ..... everything back to normal ...
I just drive it in the snow this morning....wow .
