Towing with your evo??
Old Jan 20, 2011 | 09:36 PM
  #31
panem's Avatar
evom memember Savaho's evo.
Old Jan 20, 2011 | 09:39 PM
  #32
CantStopSpinin's Avatar
Hell yeah were the only words that came to mind when seeing evo above! lol. thats awesome.
Old Jan 20, 2011 | 09:48 PM
  #33
KX250Fmotoracer's Avatar
I used to tow 2 dirtbikes, a pressure washer, and a half-full 30gal drum of water back and forth with my Dad's 95 4cyl accord, and my moms 99 Toyota Camry. Neither had a problem (I will admit, the camry was a little hairy above 45mph though haha)
Old Jan 20, 2011 | 10:00 PM
  #34
206OZEvo7's Avatar
towing a motorcycle with an evo is nothing compared to this http://www.youtube.com/watch?v=O6yj7kHHg08
Old Jan 20, 2011 | 10:17 PM
  #35
sprx19's Avatar
When I had my wrx I towed a 450 dirt bike on a small trailer with it for 2 years. The car had an 18g turbo and all the mods to go with it. It was tuned with a Utec so I just copied my normal map and added some fuel and pulled a bunch of timing. It worked great. I used tell people that my tow vehicle ran 12's. LOL
Old Jan 20, 2011 | 10:18 PM
  #36
izabran's Avatar
i pulled my friends sti after he blew the motor on it... and it was no issue...
Old Jan 21, 2011 | 11:03 AM
  #37
Chris n Rabecca's Avatar
I would not sweat pulling it... Its only 900 lbs, then no problem.... Just like rolling with 4 hefty passengers.
Old Jan 21, 2011 | 12:03 PM
  #38
pettyboy69's Avatar
i wouldn't hesitate to tow that much weight at all, especially since it is rolling weight if it messes with anything on your car there are deeper problems that need to be addressed anyway
Old Jan 21, 2011 | 05:07 PM
  #39
206OZEvo7's Avatar
keep in mind, evo has a unibody frame and it's not meant for towing unlike a body over frame small pickup which is good for towing...
Old Jan 22, 2011 | 06:02 AM
  #40
targa ten's Avatar
Most,if not all,SUV's are now unibody.They along with most cars are rated to tow from the factory.
I used 3 locations to attach the reciever to the Evo,its fine.
Using the factory tie down/tow hook gives a strong mount location right behind the hitch itself.
No worries.
Old Jan 22, 2011 | 07:10 AM
  #41
fastcolt's Avatar
That jetski set up is sweet!
Old Jan 22, 2011 | 01:53 PM
  #42
GTijoejoe's Avatar
Originally Posted by Wiznaz
I have a tow hitch with a 1 1/4" receiver for my Evo. Purchased it off this board. They say not to tow more than 1,000lbs with these cars and watch your tongue weight. I haven't used it yet but I plan to tow my Yz450F to the track next spring.
I'm curious who "they" is, but I'm 100% sure the manual states this vehicle (evo 8/9) is not towing capable....saw it the other day.
Now that being said, what does that mean?
The vehicle was never meant to tow anything, which means it never passed any gov. tow regulations/tests etc. or internal OEM tests.
In general most vehicles can tow 1000lbs, and that is because the vehicle's passenger loading/luggage is normally double that (depending on the vehicle). So fully loading your vehicle up and towing a trailer would not be a good choice.
Some reasons for towing limits are:
1) Axle gross weight (added by tonge weight)
2) Bearing loading
3) Engine cooling
4) mission/driveline cooling
5) Engine torque
6) Frame loading
7) Brake capability
Not saying these apply, just in general.
In addition, most unibody vehicles with tow packages can not attach to the subframe, so hitches are mounted to the actual white body frame, but those sections of course have increased strength/stiffness for towing capabilities.... IE look at all Honda vehicles.
Old Jan 24, 2011 | 11:50 PM
  #43
Wiznaz's Avatar
If you do a search you'd see this had all been covered in the past. I bought the tow hitch from a rally team on this board. I believe it was used to tow equipment around.
You are right about the limitations of towing and what you can get away with on the Evo. I am sorry if I hadn't explained it enough. But like I said, a simple search will pull up all the information you need.
2) Bearing loading
3) Engine cooling
5) Engine torque
6) Frame loading
7) Brake capability
Old Dec 29, 2012 | 05:50 PM
  #44
Ty-tec9.5's Avatar
TOW a Banshee With my evo
I Tow my Banshee with My Evo With noproblems every weekend
Old Dec 29, 2012 | 07:53 PM
  #45
hatesposers's Avatar
What hitch system do you use?
